Old 09-28-2006, 08:43 PM   #1
whoguy
Drives: Yaris YRS Sedan
What tyre pressure?
Hi all,
Just want to know what tyre pressure you's run with 17" 205/40 tyres?
At the moment, I'm running 40psi front, 32psi rear.....
whoguy is offline   Reply With Quote
Old 09-28-2006, 10:12 PM   #2
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
I run with 40 F and 40 R
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 09-29-2006, 12:24 AM   #3
jeff_o
Drives: 07 Yaris
Send a message via ICQ to jeff_o Send a message via MSN to jeff_o Send a message via Yahoo to jeff_o
geez... is that really how it should be when you run with low profiles? i thought even at 205/40 you should be running with 30-32psi. please correct me if i'm wrong
jeff_o is offline   Reply With Quote
Old 09-29-2006, 01:01 AM   #4
riceboy
Drives: icebox
Damn.. so high.. I run 32 all around...
riceboy is offline   Reply With Quote
Old 09-29-2006, 08:19 AM   #5
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
The manual says something about 30 psi.
Old 09-29-2006, 08:36 AM   #6
ToyVitz
ToyVitz's Avatar
Drives: 07 tC, 01 IS300, 86 Supra
What's the tires max recommended COLD psi rating? I would probably take about 6lbs off that number. Like if you have 44 PSI tires, run 38 or 37 PSI...you still want to maintain some pressure incase you were to hit a pot hole or some other road debris. You're probably running a lower profile tire too, so you'll want to protect your rims but let some out to have a smoother ride than max pressure. But remember if you let too much out you'll also wear down the outter edges of the 2 front tires a lot faster due to compression during cornering.
If you switch back to stock tires I would check the PSI rating on the door jam (if there is one...my Yaris is on order yet so I'm not sure), but they give specific PSI pressures for both front and rear for the best wear results for the listed stock tire size.
Neal
2007 Scion tC - 2001 Lexus IS300 - 1986 Toyota Supra
ToyVitz is offline   Reply With Quote
Old 12-24-2011, 02:22 PM   #7
ciscobear
Drives: Toyota Belta
Post is way old but it helped me alot. Thanks guys.
ciscobear is offline   Reply With Quote
Old 12-24-2011, 03:54 PM   #8
matthewai
matthewai's Avatar
Drives: it is kinda stock
hahah i just filled mine up to 34 all around but i have 195/55/15
merry grizzmas
Old 12-26-2011, 01:11 AM   #9
matthewai
matthewai's Avatar
please...
http://www.yarisworld.com/forums/sho...15&postcount=8
Old 12-26-2011, 11:59 AM   #10
ciscobear
Originally Posted by matthewai View Post
for 15s I used 28-30 psi
Old 12-26-2011, 12:19 PM   #11
matthewai
matthewai's Avatar
oh wow i always thought that was low maybe il try it though
Old 12-26-2011, 02:43 AM   #12
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
I run 32 front and 33 rear.I find that when the pressure drops I find the car rides better.
Old 12-26-2011, 04:19 AM   #13
I run what ever the side wall says is the max psi rating. I don't really care for ride comfort and would rather get better mpg's and turn in response.
Old 12-26-2011, 03:14 PM   #14
jo-vitz
Drives: Toyota Vitz RS
I use 28psi on 205/40 17" and is very hard...
jo-vitz is offline   Reply With Quote
Old 12-26-2011, 08:32 PM   #15
Viperoni
Drives: 2005 Toyota Echo
Depends on the tire and rim width. 30-35psi is generally good.
2006 Saturn Ion Redline
Old 12-29-2011, 09:00 AM   #16
docB
Drives: '09 Yaris Sedan
I run 35 rear and 42 front. Tire wear is good & even and the car sticks very well.
docB is offline   Reply With Quote
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 12:37 PM
stock tire pressure... argylesocks Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 09-16-2006 12:28 AM
