Old 08-20-2006, 04:23 PM   #1
argylesocks
Bears eat beets.
argylesocks's Avatar
Drives: Yaris LB
stock tire pressure...
ive been checking my mpg since i got my car 2 weeks ago.
39mpg on the first tank. 41.2mpg on the second tank.
i was excited to see pump up my tires a bit, and see if it would help.... the dooor specs them at 32psi, but the tire max is 44psi.
i check them today (barely warmed up) and they were set at 46psi !!! yikes.
thats how it left the dealship.
anyone else see this??
argylesocks is offline   Reply With Quote
Old 08-20-2006, 06:49 PM   #2
dandj
Drives: 07 Yaris sedan auto
Nope mine were @ 36 but I just uped them to 44. I've been getting 38-40+, anxious to see what happens now @ 44 psi.
dandj is offline   Reply With Quote
Old 08-20-2006, 07:06 PM   #3
riceboy
Drives: icebox
you shouldn't drive the car with tires overinflated.. it makes them stiff and reduces the footprint in contact with the road.. plus if you run into potholes or debris the tire may become damaged more easily..
ideally you should roll at the rec. 32psi... and make sure to check tire pressure with cold tires, taking the measurement after driving will increase the reading..
riceboy is offline   Reply With Quote
Old 08-23-2006, 09:14 AM   #4
esquiva
Noypi ako!
esquiva's Avatar
Drives: 07 S Sedan 5-Speed M/T
i agree w/ riceboy here...i just keep em at 32psi
...and u should give room for increase in pressure...especially when the temp rises
esquiva is offline   Reply With Quote
Old 08-23-2006, 11:04 AM   #5
argylesocks
Bears eat beets.
Drives: Yaris LB
well...overinflated is anything over the max (44psi).
the 32psi is the recommendation for the CAR manuf. for optimal comfort and handling.
actually alot of people are running higher for better fuel efficency... some (not me) even go higher than the max with no problems.
Free veggie starter kit!
Old 08-24-2006, 02:47 AM   #6
oscarying
Drives: SLOOWZ
i put mine 34psi at the fronts,and 32 at the rear
oscarying is offline   Reply With Quote
Old 08-24-2006, 10:33 AM   #7
esquiva
Noypi ako!
esquiva's Avatar
do u have a reason for that?
Nagka-anak sina boy at nene, isang lalaki at isang babae. binata't dalaga na sila...
Nene jr.: tay, peram naman ng kotse o...
Boy Bastos: sige pero isang kondisyon. mag-ano muna tayo.
Nene jr.: tay meron ako ngayon e. blowjob na lang kita.
Boy bastos: o sige.
pagkatapos ng blowjob...
Nene jr.: tay, bat lasang tae yung etits nyo?
Boy bastos: ah ganon ba? hiniram kasi ng kuya
mo kanina yung kotse e!
Old 08-24-2006, 01:39 PM   #8
ketel0ne
ketel0ne's Avatar
Drives: 2007 Liftback Blazing Blue
I put 40 in my RE92's (it was a warm day) They sit at 44-46 when hot.
ketel0ne is offline   Reply With Quote
Old 08-24-2006, 11:11 PM   #9
swng
swng's Avatar
Drives: 06 3-dr auto RS
Mine is 34 psi all around. The manual says 32 psi. However, I think my tire pressure gauge may not be very accurate and I prefer to err on the high side. I believe it is more risky to err on the low side (e.g. leaking over time may make the pressure even lower). Also, I like the slightly better handling and fuel economy that comes with +2 psi.
swng is offline   Reply With Quote
Old 08-25-2006, 01:03 AM   #10
oscarying
Drives: SLOOWZ
i feel that handles better but duno why sorry
Old 08-25-2006, 01:38 AM   #11
swng
swng's Avatar
In my humble opinion, a higher tire pressure can make the tires stiffer and hence produce an effect similar to that produced by sportier (harder) suspensions, hence better handling. There is, however, a limit to how much one can overinflat as far as comfort and safety are concerned. Among other things, an exceedingly high tire pressure may often result in a stiffer ride and a longer braking distance.
Old 09-16-2006, 12:28 AM   #12
fred812
Authorized User
fred812's Avatar
Drives: 2007 5 spd Hatch White
Less contact area will also reduce wet stopping distance! Thats when you need it most. I love the feel of the higher pressure, on every toyota I ever had then it rains and I go back to what the Car says, not the tire!
fred812 is offline   Reply With Quote
Stock 6 disc MP3 deck + speakers for sale!!! chino_potato Items for Sale by private party 16 02-05-2009 07:27 PM
Tire Pressure slvryaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 11-05-2006 12:37 PM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
question about stock stereo wiring? punch In Car Entertainment + Electronics (audio / video / alarm) 3 07-19-2006 03:22 PM
