AC not working, AC compressor pulley rattling
My AC stopped working and I did some looking around fuses good, ac system is charged. I noticed a rattle on the compressor pulled at the same time I noticed my serpentine belt was really cracked. Got the belt changed but they didnt want to tighten it down due to the rattle in the compressor claiming it could break.
So now I have a squealing belt and no AC. I have ordered a re-manufactured AC compressor with clutch and pulley any tips on replacing it, can I do it myself? Is there a how to by any chance? |
#2 | |
Replacing the compressor is straight forward, but evacuating and charging it will require bringing it to a shop. The Air Conditioning section of the service manual shows the step by step of replacing it. You can download it from the Micro Image Forum: http://www.microimageonline.com/foru...32-YARIS-FILES
cant charging be done with the recharge kits at any autoparts store?
I bought one with a guage thinking mine was low so I have a full large bottle and gauge |
Those are "kind of OK" for recharging a system that is a little low, but not good for an empty system that has been exposed to air. The moisture and particulate that got into the compressor and system while disconnected will cause very premature failure if you simply charge the system without evacuating it. The evacuation process involves using a suction pump to draw an extreme vacuum on the system, which removes any moisture and impurities.
thanks, looks like ill just have to find someone to do the install for me
| Help re my rattling Yaris! | lou3939 | DIY / Maintenance / Service | 2 | 03-11-2012 03:25 PM |
| STOP RATTLING WHERE? | xbr3akd0wnx | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 01-10-2012 08:39 PM |
| Electric Windows Stopped Working !?!? | MattyP | DIY / Maintenance / Service | 0 | 09-14-2010 08:20 AM |
| Valet 712t not working | yaris prime | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 04-23-2009 07:53 PM |
| Working at Volkswagen | elsteverino889 | Off-topic / Other Cars / Everything else Discussions | 22 | 05-07-2007 08:29 PM |
