Old 01-09-2012, 04:07 PM   #1
xbr3akd0wnx
Meow
Drives: 2008 Yaris, White Hatchback
STOP RATTLING WHERE?
HI
I was wondering where i can place a few dynamat slabs to stop rattling in some obvious areas that you yarisworld members have come across? Rattling in the interior of course!!
I have a those asian clip on rectangular mirrors for my rear view mirror and it rattled so I put a slab on there. Other than that, I hear rattling in a lot of places but I cant seem to find the right location to stop the rattling????
HELP ??
xbr3akd0wnx is offline   Reply With Quote
Old 01-09-2012, 04:37 PM   #2
A-Dingo-Ate-My-Baby
Drives: yaris
you could:
1) remove all non-car parts. get all personal junk out of car
2) get a passenger who can locate rattles
3) you drive around and let the passenger zero in on rattles, front and back
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 01-09-2012, 04:51 PM   #3
yaris2010RS
yaris2010RS's Avatar
the trim infront of the cluster rattles against the cluster itself and at the vents, rear cargo flap rattles, a component inside the door lock little black box rattles(fixed with lithium grease), door pannels rattle (bottom and side) dash board against windshield rattles, in engine bay metal part under the front wiper cover rattles, mastercraft socket under spare tire rattles, jack inder seat can rattle. THE STUPID AIR VENTS ON THE SIDES OF THE DASH SQUEEK!!! fixed with crazy glue all the way around where the vent meets the dash
Old 01-09-2012, 07:16 PM   #4
xbr3akd0wnx
Meow
Originally Posted by A-Dingo-Ate-My-Baby View Post
you could:
already did this. posted this question up so i can find specific area but thank you
Old 01-09-2012, 07:18 PM   #5
xbr3akd0wnx
Meow
So i put so on the underside of the black thing inbetween the cluster and the air vent. I looked at dericks SQ thread and found the places to put mat on the door panels. a LOT less rattling now when the volume is turned up!!
Any other areas I sound look into while my car is apart for now?
Old 01-10-2012, 10:13 AM   #6
Crackerballer
Drives: 08 BMW 135i
Has anyone noticed a REAL decrease in rattles with some chassis bracing? Does a STB or any under bracing help at all?
I will also second the door panels, especially when playing music loud. The cluster area too, I am going to do my best to fix that soon.
Also, a good set of wheels, tires, and a good alignment should help fight the good fight.
Crackerballer is offline   Reply With Quote
Old 01-10-2012, 11:21 AM   #7
A-Dingo-Ate-My-Baby
Drives: yaris
dang
I have 28,000 on a 2010 HB and I have ZERO rattles
I am someone who also will go apesh*t if there is a rattle. All rattles
I ever had were due to something I brought in the car, not the car itself
OK ...ONCE the passenger seatbelt height adjuster rattled so I smacked it.
what the hell is with your cars, 'cuz mine is fine.
Old 01-10-2012, 12:52 PM   #8
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Holy cow - what do you guys do to the poor Yaris? Mine has zero rattles and a stiff ride to boot.
Old 01-10-2012, 02:54 PM   #9
xbr3akd0wnx
Meow
Well so far, my dashboard is a fiberglass one I got from Garm a few months ago (it used to be purple but now its grey!). The fit was around 90% perfect. There wasn't that much rattling in the beginning and I fixed those problems ASAP. But slowly more and more rattling came as I got a subwoofer and man, that really rattles things up!!
I've always wondered this too!! Anyone have any input on this?
Old 01-10-2012, 06:52 PM   #10
Crackerballer
Drives: 08 BMW 135i
If you don't have rattles on your Yaris your music isn't loud enough and you're not driving it hard enough :D
Old 01-10-2012, 07:39 PM   #11
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
as for me :
piggyback a couple of scion 8"bazookas inplace of sparetire
a bunch of loose change in lower dash compartment box
pens and tiregauge in upper dash compartment
my 2yr old daughters McD happy meal plastic toys in glovebox and upper pass compartment
OTA'sTOY is offline   Reply With Quote
Rattling noise FunkyCole DIY / Maintenance / Service 10 08-27-2015 06:28 PM
Made my first stop motion video YarisSedan Off-topic / Other Cars / Everything else Discussions 11 12-09-2011 11:41 AM
NF210 bump stop cutting? Taiyaki Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 11-07-2010 05:19 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
rattling TickleTimeTim General Yaris / Vitz Discussion 3 03-01-2009 01:37 AM
