Old 03-30-2012, 06:31 PM   #1
coffiend
coffiend's Avatar
Drives: 08 Black LB
Front suspension knocking.
My drivers side front suspension started knocking today. It doesn't knock over bumps really and only knocks when I'm coasting, not when I have my foot on the accelerator. I can feel the knocking slightly in the steering wheel. I looked down there and there's some tarry black crap splattered around my wheel behind the brake. Any ideas?
Old 03-30-2012, 07:03 PM   #2
coffiend
coffiend's Avatar
Drives: 08 Black LB
heres a little video to show you, the knocking stops when i accelerate and brake...
http://youtu.be/us_W8S-rjSA
Old 03-30-2012, 07:19 PM   #3
auxmike
auxmike's Avatar
Did you take the tire off and check for a torn rubber Cv joint boot? Engine mounts?
Dunno, but it sounds BAD and unsafe...
Old 03-30-2012, 08:24 PM   #4
coffiend
coffiend's Avatar
Drives: 08 Black LB
i haven't had a chance to do anything, I barely got it home, and now its raining outside unfortunately. I was just seeing if anybody might have any ideas before I get into try to figure it out.
Old 03-30-2012, 08:27 PM   #5
coffiend
coffiend's Avatar
Drives: 08 Black LB
pictures
Old 03-30-2012, 08:36 PM   #6
auxmike
auxmike's Avatar
Just as I thought. That knocking means their's something majorly damaged or loose. The car was lowered?
Old 03-30-2012, 08:52 PM   #7
coffiend
coffiend's Avatar
Drives: 08 Black LB
Well, turns out the horrible knocking was from 2 of the lug nuts backing out. The wheel was vibrating all over the place. The 3rd backed out 1/2 way and luckily #4 was on snug. That could have got real sketchy, still gonna take it in to check out the gunky business... No idea how those little bastards came loose.
Old 03-30-2012, 08:55 PM   #8
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
There is a giant hole in your cv boot...just in case you missed that.
-Type 07 FFL-
My odometer 03/11
Old 03-30-2012, 09:22 PM   #9
coffiend
coffiend's Avatar
Drives: 08 Black LB
Ha, yes, I do see.
Thats not where the knocking came from, though, it was the lugs.
But I'm going to probably just have to do a whole new axle assembly, thats usually the easiest / cheapest way, isn't it? (or so I hear)
Old 03-30-2012, 09:33 PM   #10
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Damn that could have ended bad. But yea I was gonna say something chewed into your cv boot.
Old 03-30-2012, 09:51 PM   #11
auxmike
auxmike's Avatar
Check the rim, wheel studs and lug nuts for damage. Also, who was last to remove those wheels? Hoping it wasn't sabatoge....
Old 03-30-2012, 09:54 PM   #12
coffiend
coffiend's Avatar
Drives: 08 Black LB
ha, it was me. It all lies on my shoulders. I don't know what happened, they have been on tight for a good 2 months and all of the sudden they backed out, idk. The existing lug nuts look fine as well as the studs. The rim looks okay too. I can see if I just didn't tighten one right but don't you think they would have come off in less than 2 months time? Weird shit.
Old 03-31-2012, 01:05 AM   #13
mazilla
advocatus diaboli
mazilla's Avatar
Do your rims sit firmly on the hub, or is there play? If there's play you can easily
torque the rim off center and it will eventually work itself loose. You should be tightening your lug nuts while the tires are still off the ground. When you feel their as tight as you can get them by hand(because the wheel will eventually turn) give the tire a couple good kicks and make sure it doesn't settle in anymore.
Then drop the car until there's just enough weight on the tires to keep them from spinning while you torque them down... then drop them all the way and recheck torque one last time.
Hub centric rings will help if they are applicable.
-Type 07 FFL-
My odometer 03/11
Old 03-30-2012, 09:59 PM   #14
I have an extra axle assembly with 20000km on it....pm me if you need it...ill let it go cheap
Old 03-31-2012, 07:29 PM   #15
coffiend
coffiend's Avatar
Drives: 08 Black LB
Honestly, I think it was either somebody trying to steal my rims (I don't live in the greatest neighborhood) and got scared off by my dog... or I was just lazy and careless when I switched them out, most likely it was my laziness. It was a good wakeup call, though! haha.
Old 03-31-2012, 07:33 PM   #16
returned your PM about the axle
Old 03-31-2012, 09:38 PM   #17
auxmike
auxmike's Avatar
Yeah, that sound in the youtube vid is VERY frightening!
Old 03-31-2012, 10:58 PM   #18
Hershey
Good thing you caught it early . Hope you have better days ahead .
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
front end damage mystery yaris9876 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 06-02-2009 04:13 PM
Displaying Front Plate In CA hans_fh California 42 10-22-2008 12:57 AM
