Drives: 2011 Yaris 4 Dr. Sedan Join Date: Sep 2011
Ultra Racing rear sway bar
Ultra Racing make 19mm and 23mm type. Not sure what size I should use for my 2011 Sedan. I do not want to make the car rough riding, as after all it is a Sedan driven gently.
Also, if there is a different brand (better) I would concider it. Any input would be appreciated.
Ratz --------------------------------------------------- Cleverly disguised as a responsible adult.
Mr. 155 and climbing
The 19mm is just fine for street use with spirited driving
![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
23mm,23mm,23mm. Rough riding only when you lower and replace the shocks. I got stock suspension but with all the Ultra racing bars. You will feel a big difference when you making a tight corner turn. Also,UR available rear stabilizer bar too.
I got the 23mm for my DD and I love it .
Yes, it will stiffen the rear suspension a bit like either sway bar will but in a great way. You wiil no longer feel like you are driving a boat. In any event, it can not in any way be considered harsh, or rough riding.....just balanced between the front and rear. Keep in mind that the Yaris already has a good stock front sway bar. It has be said that one can not reallly feel the difference between the 19mm and the 23 mm until you reallly push the car and then, you can feel the benefits of the 23mm bar. So, get either one from UR and you wiil not be disapointed!
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I have a 23mm on my sedan and couldnt imagine going smaller
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
These bars don't change handling in a straight line, they don't make the suspension stiffer that way, though the car will resist buffeting from winds and passing semis a LOT better.
#7 | |
Also, when one thinks abouit it, unless both wheels are focrced up (by the road) by exacly the same amount every time, the suspension will feel a bit stiffer but, in a very postive way.
Thanks everyone looks like the 23mm is the one. Will order it tomorrow.
Form>Function
What about that Nitto Rear lower shock brace? Ive seen it in your store and am curious. What is the difference between that and the sway bar? Does it stiffen the dampening of the rear suspension? Or does it stiffen like a sway bar, side to side?
The sway bar (actually a torsion bar with a beam rear axle like we have) resists twisting by transferring weight to the OPPOSITE FRONT corner. Preventing roll translates into more traction on the front inside tire.
The rear trailing arm brace (rear underbrace) boxes in the trailing arm - beam - trailing arm "U" shape, providing more stiffness, and resistance to deformation. The rear of the car feels "tighter" or "crisper" with this brace in place.
![]() ![]() Drives: 2008 3dr Join Date: Oct 2011
from someone with the 19mm....
get the 23mm ![]() I will probably upgrade mine at some point, the 19mm is a lot better then not having one by leaps and bounds, i can only imagine the 23mm is that much better with really no ill effects. i dont really drive hard, but i do still notice a little getting blown around, and i'm sure tires/rims will probably suffice for me since i'm still way up in the air with only an inch drop. however as slow as i go on the highways people wondering wtf i'm doing when i dont bother slowing down to get off an offramp is great Last edited by randeez; 04-12-2012 at 09:59 PM. Reason: cant type |
Form>Function
I speed up for on ramps
^ LOL, yeah that's the spirit!
![]() ![]() Drives: 08 Yaris S 3Dr Join Date: Mar 2011
I went from 19mm to 23mm and it was a noticeable difference for me especially on the freeway...
![]() yes, i hear my babysmama gasp everytime i wing it towards an offramp if shes with me. |
glad to see a consensus on the 23mm size... placing order shortly. thanks to all contributors. I'll update with my experience once it's on and driven around for a bit.
Part arrived on schedule but I didn't get around to the installation until this past weekend. The test drive was fun, definitely a noticeable reduction in roll around corners. If you are thinking about this upgrade, I cast my vote for yes, go for it!
#18 | |
What counts is you are happy. Congratulations.
| TRD rear sway bar? | Lewis | DIY / Maintenance / Service | 26 | 09-10-2013 02:10 PM |
| Yaris Rear Sway Bar Install ? | Spork | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 03-20-2012 09:17 PM |
| My Ultra Racing rear sway bar install | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 49 | 03-03-2011 02:08 AM |
| WTB Rear Sway Bar | nick.dollimount | Willing to Buy by private party | 2 | 05-27-2010 02:44 PM |
| rear sway bar needed | vten | Willing to Buy by private party | 11 | 11-22-2009 11:50 PM |
