Old 05-27-2009, 08:47 AM   #1
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
Question TRD rear sway bar?
I've ordered a TRD rear sway bar for my 2009 3dr Yaris. First I'd like to know if anyone has installed this on a base car with no other alterations- and if so- was there a noticeable improvement in handling prowess? Secon did you do it by yourself and how difficult is the install- the ads say it's a 10 minute job but the instructions seem to suggest it'd take the likes of me a couple of hours.
Thanks in advance for the information!
Lewis is offline   Reply With Quote
Old 05-27-2009, 08:56 AM   #2
1. You will notice the difference for sure!
2. I'd say more like 30 minutes for a slowpoke like me.
3. The Ultra Racing bar I sell is less expensive and the same quality.
4. Search "sway bar install" and you'll find my DIY step by step on this forum.
Old 05-27-2009, 09:11 AM   #3
Klink10
Klink10's Avatar
^^^^^What he said. First mod I made.
Old 05-27-2009, 10:19 AM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
+2
Easy to install and you will definitely notice a difference.
Old 05-27-2009, 10:31 AM   #5
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Very Big Difference... BIG =) and EXTREMELY EASY TO DO
Its a Chao!!!
Old 05-27-2009, 10:44 AM   #6
DerFlosser
DerFlosser's Avatar
Very easy...especially with a lift. Directions are straightforward and the configuration is basic common sense.
DerFlosser is offline   Reply With Quote
Old 05-27-2009, 11:00 AM   #7
Tamago
Tamago's Avatar
Drives: UZJ100
i installed without jacking the car up
Old 05-27-2009, 01:37 PM   #8
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Incredibly easy to install, and it makes a massive difference in how the car feels.
Old 05-27-2009, 02:25 PM   #9
TheSilkySmooth
TheSilkySmooth's Avatar
Is a big difference GOOD or BAD? Can you induce snap oversteer on the highway at 70MPH? I dont want to end up in the weeds going backwards at 60 MPH. The car is pretty neutral FA oversteer goes with a slight proclivity to oversteer on abrupt transitions at speed. The car leans over like a Lincoln though, stock.
Old 05-27-2009, 03:29 PM   #10
schleppy
I love momentum.
schleppy's Avatar
It's a good difference. The car turns a lot tighter and it feels like the rear end is finally oing something. The body roll can only be cured with better springs/shocks.
The only way you're going to end up with snap oversteer on the highway is if you're doing something absolutely ludicrous. Something so ludicrous that it probably would have happened without a sway bar.
Old 05-27-2009, 05:18 PM   #11
TheRealEnth
Beast
well i was taking a pretty good turn at 105 today and i didnt oversteer, then again its the driver... but yeah you arent going to go 70 and start oversteering.... the car was lifting tho... i need more downforce =(
Its a Chao!!!
Old 05-27-2009, 05:44 PM   #12
MUSKOKA800
MUSKOKA800's Avatar
Installation: Easier than changing a tire. A no-brainer you might say.
Significant improvement in handling, road manners and safety. One should be installed on each Yaris by Toyota factory workers. It's that much better.
Old 05-27-2009, 06:03 PM   #13
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
Best mod for the money on a Yaris period.
Bob Dog is offline   Reply With Quote
Old 05-28-2009, 09:17 AM   #14
TheSilkySmooth
Well, when you have an "Emergency avoidance maneuver" It will put the suspension to its limit. So I will know what its going to do in a fast lane change, I test it when there is less traffic by slalom-ing about a half lane out of my lane at about 70-75 MPH. With the stock setup with 15" bridgestones with 29psi in the rears, the rear will start to slide, wag or fish tail about a couple inches during this maneuver. I would imagine if I stiffened up the rear, this might become unmanageable and the car would have UNSAFE emergency lane change capabilities. - Anybody want to try and report back, or are you uncapable of advanced driving?
Old 05-28-2009, 09:58 AM   #15
TheRealEnth
Beast
well ... when i slalom'd on stock setup... it felt like i was gonna die =D.. But now with my setup... i can slalom at 70 and it feels controllable... and fun... but i also have a lot of suspension mods already added.
Its a Chao!!!
Old 05-28-2009, 06:33 PM   #16
Lewis
Lewis's Avatar
Smile
I am an ordinary driver and wondered about the rear bar. for my day use Based on the responses in the forum I went for it and boy am I glad I did. The car feels MUCH more stable - planted on the road - with WAY less body lean. No noises etc with the bar so it's a big win/ win.
I installed it myself and it was not as easy as it looked in the directions All told it took me almost 3 hours due to the access tightness around the front nut and bolt. I am a perfectionist and alway torque the bolts to spec and the limited access (even with jackstands and the wheels off) made it very difficult to get my torque wrench on the nut and bolt to insure I got exactly 44 ft. pounds on it.
Despite that difficulty I'd do this mod again tomorrow if I had another Yaris- it's really worth it. Just a shame Toyota didn't spec the car stock with a more stiff rear axel so all that work would have been unnecessary in the first place- I saw these Yarises all over Italy on my last trip there and I bet you dollars to donuts the Italian Yarises come with enough roll stiffness in the suspension stock- they'd never buy them over there if they were this wobbily!
Thanks to all on the forum who urged me to go ahead- GOOD advice was given!
Old 05-28-2009, 07:02 PM   #17
Tamago
Tamago's Avatar
Drives: UZJ100
hub spacers next! www.penguingarage.com
Old 05-28-2009, 08:56 PM   #18
TheSilkySmooth
Sound good, guys! I guess its not a REAL sway bar per se, just stiffens the twist beam axle ( Previous generation VW Golf (that handled better IMO) used to use twist beams - I like 'em:) AND, two less wheels to go out of alignment! Just a bit dicey if you find yourself going backwards over 40mpg ...
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 10:29 AM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
