Old 03-28-2009, 11:17 PM   #1
detroiter
detroiter's Avatar
Does the TRD rear sway bar promote tire wear?
Just wondering if the sway bar promotes tire wear on the rear tires outer edges? Aside from taking turns faster, that obviously would wear out quicker but since it keeps the rear firm and less sway when the car turns, does that put more weight on the outer edges instead of letting the rear torsion bar just flex a bit more thus not putting more force on it?
Old 03-29-2009, 02:36 AM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
No, you won't see any more wear than normal provided you keep the same driving habits.
Old 03-29-2009, 07:37 AM   #3
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
There's the kicker. The rear swaybar is likely to inspire you to corner harder and faster, which will increase tire wear.
But, the bar in and of itself won't affect tire wear at all.
Old 03-29-2009, 10:29 AM   #4
kngrsll
Apexing Egg!!
kngrsll's Avatar
i cant believe how often this comes up! maybe stick this in the suspension primer? a "what effects tire wear" category perhaps?
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD sway bar and tire wear Cutie Pie #2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 02-01-2009 08:07 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
Difference b/w TRD Rear Sway Bar and these? IsLNdbOi Performance Modifications 8 11-11-2008 09:13 PM
