Old 02-28-2014, 08:39 AM   #1
bentjazz
Drives: 2009 Yaris--3dr MT
How long have you ever gone between oil changes?
Hi Yarisworlders,
Just curious the longest you guys have gone between oil changes. I'm kind of anal retentive about changing the oil, but am thinking about easing up my intervals a bit....
Thanks.
bj
bentjazz is offline   Reply With Quote
Old 02-28-2014, 09:20 AM   #2
CB900F2
Drives: 08 Sedan
Using amsoil and doing 15k km between oil changes
Old 02-28-2014, 10:05 AM   #3
Most I've done was 13 months/ ~14k miles. Using Amsoil oil and oil filter.
Old 02-28-2014, 10:08 AM   #4
harda toenail
Drives: Want a yaris
I've never gone over 3k miles. But I never drive far at all. 3k miles is about 6 months for me. I tend to change it before and after winter, and once in the summer.
harda toenail is offline   Reply With Quote
Old 02-28-2014, 10:10 AM   #5
Idahotom
Drives: 2008 5 sp. LB
Mobile 1 and about every 10K, that's about 8 months for me.
Idahotom is offline   Reply With Quote
Old 03-29-2014, 12:57 AM   #6
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
Done that with my last four cars. Never seen it burn...
Always comes out looking new.
trunkout is offline   Reply With Quote
Old 03-29-2014, 01:01 AM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
To be completely blunt you can't just "look" at used oil. That does not a bit of good. Case in point is a guy on the new 1nz Enthusiasts Garage from PR. He had an analysis report done on his Royal Purple. He was pretty disappointed because it always "looks" good.
From my m-o-b-i-l-e
Old 04-05-2014, 12:11 AM   #8
frambach
Drives: 2008 Liftback
From my m-o-b-i-l-e
A person can draw no conclusion on the state of their oil by simply looking at it other than to check the current oil level.
I've never seen Royal Purple perform overwhelmingly good in any real test (going back 3+ years). It's just a middle-of-the-pack, well marketed motor oil in my opinion.
Originally Posted by malibuguy View Post
I run amsoil 0-20w with a corolla amsoil filter. 15k intervals and im at 73k. Motor runs amazing and is gorgeous inside.
What filter number is that? What's the benefit of running it over the recommended filter for the Yaris?
AMSOIL has discontinued the EA15K10 if that's the filter you were running, you're going to have to revert back to the EA15K09.
Originally Posted by Exiwolfman View Post
We'll than the problem is not so much the oil but filtration a better way to keep it clean as the article states ,it can last a long time . That maybe true problem is that it brakes down do to the contaminants like I said I see what comes out ....I for one do and always will change my oil at 5k ...longer life ,sludge free engine .
Wolf, if you could see the inside of the motor was clean and you got back a used oil analysis with 5,000 miles on the oil that said 'your oil is absolutely perfect, there is no need to change it right now', would you still walk outside and drain the oil?
Filtration is not the issue either. With a completed analysis, there would be tell-tale signs that the oil filter was no longer effectively doing it's job and that's not happening. I'm looking at my most recent analysis in another window while I type this. The following are families of metals that are all checked on a UOA:
- wear metals
- contaminant metals
- multi-source metals
- additive metals
They're all good! I can take off my oil fill cap and shine a light in my valve cover, it's so clean! When I remove my oil dipstick, there aren't any varnished up spots on it. My dipstick looks like it did the day the car had 1 mile on it. You know how dipsticks will get that used oil 'glaze' in certain spots? Not mine.
frambach is offline   Reply With Quote
Old 02-28-2014, 10:19 AM   #9
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
Personally, I do the 5k oil change.
I was once part of a gas saving forum. There was a guy their touting this stuff called synlube (syn-lube) that was supposed to be a once in a lifetime oil change. I am no longer a member on that site (actually web site doesn't exist anymore) but last I heard, he was at 56,000 miles without changing it. We were all waiting for something catastrophic to happen.
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 02-28-2014, 10:25 AM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
once a year oil change is possible with a bypass filter.
Most i've done is 10k km.. about 6.2k miles. I should stick to 5k oil change, but i think i will go with 3k changes, since i'm doing alot of short trips and condensation seem to build up in the winter.
Old 02-28-2014, 12:24 PM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
mobile 1 every 5k.....for the ppl that are doing it at 10k to 15k is just ridicules....ull pay for it in a long run. Also can and will void warranty .
Old 02-28-2014, 01:14 PM   #12
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
10,000kms with synthetic oil is my routine, my last 2 Toyotas have gone 300K kilometers and never had any oil related problems.What problems do you expect me to pay for in the long run?
Have Yaris will travel..
Old 02-28-2014, 03:38 PM   #13
nookandcrannycar
What do you consider a long run ? My longest interval between oil/filter changes on my Yaris has been 34,014 miles. I followed that up with the shortest interval (2,430 miles) re the next oil/filter change. My oil/filter change intervals through about 235k miles (15 changes with the last one at just under 226k ) are on post #62 (Page 4) on narly charley's Post your oil change regimen! thread (5 page thread started January of 2013). My 16th oil/filter change (post 76, page 5) was at 240,010 miles. I had Gullo Toyota change my spark plugs at about 208k miles, and they said my engine was in great condition at that point. They looked for things to recommend to me to do, and all they could come up with was the air filter...I had already purchased one (not at the dealership) and put it in right after I drove away from the dealership.
This new thread bentjazz just started has motivated me to plan time over the weekend to update my logbook (Thanks bentjazz! ). I keep all of my receipts in chronological order. I also write the miles on car, miles on tank, and MPG on each receipt (I record these while still at the pump)....so updating my logbook (last entry = August 2013 IIRC ) will be pretty easy. I just had my oil changed last week (274,071 miles)....only about 7k since last change, but I needed the free battery check. So 240k =16th, one at about 266-267k and probably one between 240k and 266-267k. So I'm at 18 or 19 changes overall....18 would put me at a bit over 15k between changes as an overall average. Other than tires/batteries/spark plugs/air filters/bulbs, etc (routine maintenance at extended intervals), and recent rear end damage (paid for by other driver's insurance company), the only repairs I've had to do are front wheel bearings at about 110k and a new alternator at about 159k. Still original clutch, transmission, all brake parts including pads and shoes, radiator (never a flush, just added coolant 1x), hoses, water pump, fuel system, exhaust system, engine (only 1 plug change and oil/filter changes as above and on narly charley's thread), AC system (never have had to touch it) etc.
Last edited by nookandcrannycar; 02-28-2014 at 04:04 PM. Reason: added: (not at the dealership)...after the words purchased one
Old 02-28-2014, 04:00 PM   #14
nookandcrannycar
I knew a guy in the late 1970's (became stepfather to one of my best friends). He had a big Chrysler that was about 10 years old (or more) and had 160k-170k+ miles on it. He claimed that he had never changed the oil on this vehicle. Knowing him.....and seeing and hearing the car....I think this was possibly the case .
Old 02-28-2014, 04:15 PM   #15
nookandcrannycar
^^^^^BTW, all dino oil.....no synthetic.
Old 02-28-2014, 03:16 PM   #16
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
I usually change my between 4500 and 5000 miles, which is about every four months for me.
MyzticZ3r0 is offline   Reply With Quote
Old 02-28-2014, 06:06 PM   #17
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
all i can say do what you like , i work on cars everyday and see the importance of oil change. I find ppl are just cheap or lazy to keep to the 5k -8k interval ur car ur money..i see first hand what comes out in the cars with oil that was driven for over 10k...oil is just oil dont matter who makes it looses its viscosity and the ability to protect ur engine.
I have seen two , one a rav4 with no oil change since new with 89k when it came in with a blown engine..second a 2 yr old Venza 40k since the last oil was more like sludge.
Call me old school but i believe that best thing u can do for ur car is a regular oil change, specially with the new thinner oils that modern engines run..its like water. Yaris runs 5w30 or 0w20 syn or even 5w20 i did try 0w20 and did not like it more like the car did not like it, like i said its like water.
I use mobile 5w30 mainly cos of the cold weather start ups otherwise reg 5w30 is just fine the believe that u can run syn longer i dont think has any ground ...when i do my oil change after 5k it comes out clean not black ...but that is just me my car .
If everyone looked after cars like i do I would be out of work..lol
just my 2cents on this topic
Old 02-28-2014, 08:31 PM   #18
nookandcrannycar
I was just having a little fun (why I inserted the and ), but totally my fault that that didn't come accross -- on my part. I apologize . I truly, truly didn't mean to offend you. Of course more often is better. Except on things that have to do directly with safety (control arm bolts, brakes, anything else re steering, tread on tires = among what come to mind), I try to sort of play 'virtuoso of value' (squeezing the most out of the least) just to see if I can. If any of the things you mentioned happened, I would just buy a new car (given the miles on my current Yaris). I've looked at it that way for a long time. I realize everyone can't look at it that way, and I try not to be insensitive to that (especially these days), but sometimes I fail. Until recently, I thought (unconditionally) that I'd keep my Yaris after getting another one and either (to learn something new) try to teach myself how to fix it, or pay someone else to do the work (not letting it go because I'd have full knowledge of its history since new). Now I think that that will depend on mileage, what other cars are available at the time, and other factors.
Just out of curiosity (I really don't know, but am curious), are the issues you mention more likely to happen to owners who live in areas where harsh winters are the norm?
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Yaris XP9 diesel 90hp burning oil bubu DIY / Maintenance / Service 3 12-04-2013 02:08 PM
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 01:12 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
