Old 12-03-2013, 04:02 PM   #1
bubu
Drives: Yarsis 2007
Yaris XP9 diesel 90hp burning oil
I have a 2007 Yaris 1NDTV diesel 1.4 90 hp with ~130.000 km
Story 1
light came up for oil ( lower than minimum)
added 2 L of oil - dissapeared in 1 week ~ 300k
Story 2
made a complete revision at Toyota with original oil
=>maximum oil level
half indicator after ~8000km
added ~800 ml to the engine...
=>maximum oil level
after 2 days(30km) oil level is reduced about one quarter
Note :
I check oil level under the same conditions in the same place.
Turbo was visually checked at least twice there is oil inside but small quantity
no oil under the car also checked twice by Toyota and other service
cooler level looks the same ...
no black or blue smoke
any ideas ?
bubu is offline   Reply With Quote
Old 12-03-2013, 04:16 PM   #2
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I didn't watch this because it was 24 minutes long, but it might be worth checking out.
https://www.youtube.com/watch?v=N4qwFE8jTzc
Old 12-04-2013, 01:06 PM   #3
bubu
Drives: Yarsis 2007
I have no DPF...
Old 12-04-2013, 02:08 PM   #4
Check your oil filter. If the oil filter was changed and the old gasket came off the old filter and stayed behind, then with two gaskets, when the oil gets hot the oil will leak between the two gaskets, but then it will stop when it cools down.
I need to locate oil filter diesel yaris 2010 oscargo9 DIY / Maintenance / Service 0 07-17-2012 05:08 AM
Transmission Oil for Yaris 1st Gen adigilani DIY / Maintenance / Service 3 10-23-2011 02:48 PM
