![]() ![]() Drives: 07 hatchback Join Date: May 2012
Help turning off DRL
So I saw the post about turning off the DRL and actually removed the relay but the lights were still on. I know there is an auto dimmer setup in the car which I could also so without but I have no idea what HID kit was installed or what else might have been done in the process.
Any help would be much appreciated |
If you have an HID kit, then you need to start at the headlights and work your way through the wiring to figure out how it is wired up. Snap an post pics and we should be able to help.
I have found it has a dei 545t auto dimmer system would this be why I can't turn off the lights with the normal drl relay removed
That is probably at least part of it.
Ok with the removal of the DRL relay and the DEI 545t the lights don't come on so I removed the DEI module and wiring completely. Thanks for the help
in the process I also found where my entry alarm system module is so that was good :) |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
| Hid bi xenon problem need to keep drl due to fogs | marcus | Cosmetic Modifications (Exterior/Interior) | 4 | 06-20-2010 12:01 PM |
| Disabled drl and installed hids and now no fogs... | 604yarisrs | Cosmetic Modifications (Exterior/Interior) | 10 | 02-14-2010 12:26 PM |
| 2006 Yaris clicking/clunking when turning | heistp | General Yaris / Vitz Discussion | 1 | 10-13-2009 09:48 AM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 06:37 PM |
