#1 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
Hid bi xenon problem need to keep drl due to fogs
Need ur help guys unfortunetely the single bulb no xenon I bought did cause flicker weird thing is we tried it on one side and it works no drl no flickering nut once I connected both of them that's when he'll got loose flickering when I start the engine I need to keep drl due to fogs also have hid on fogs too now how do I get this bi xenon to work and also keeping drl relay due to fogs. Thanks for the input guys
Drives: 07 Yaris Sedan Aero Join Date: Oct 2006
just keep the relay, and disconnect the BLUE wire on from the DRL box..
#3 |
toyota
And that will keep the fogs too I'll try that tomorrow thanks
#4 |
toyota
can anyone confirm if i can just unplug the blue wire or does it have to be cut.. thanks
#5 |
toyota
ok got it done by dicsonnecting the blue wire fr the drl relay..just a reminder for others..you dont have to cut it..just poke a mini flat screw driver to get the pin out for that blue wire.. no drl/no flicker. low and hi mechanical worked like a charm..
| Can anyone confirm if we can relay hid on yaris with drl? | marcus | Cosmetic Modifications (Exterior/Interior) | 0 | 06-10-2010 12:38 PM |
| Disabled drl and installed hids and now no fogs... | 604yarisrs | Cosmetic Modifications (Exterior/Interior) | 10 | 02-14-2010 12:26 PM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 06:37 PM |
| xenon hid light bulb | lilman717 | Cosmetic Modifications (Exterior/Interior) | 7 | 12-19-2008 08:07 PM |
| HELP!! HID problem | 07yaris_fe | General Yaris / Vitz Discussion | 2 | 11-20-2006 06:00 AM |
