Old 07-27-2012, 05:52 PM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
FS Ksport Springs
SOLD
1.5 is offline
Old 07-28-2012, 09:28 AM   #2
1.5
Form>Function
1.5's Avatar
bump pics up
1.5 is offline
Old 07-28-2012, 01:52 PM   #3
otterhere
Drives: 2008 Yaris 3-door Meteorite
$60? I'll have to pay to ship to KY, as well as pay to install (I'm a ditzhead girl). If too low, no pun intended, let me know how low you'll go! Thanks.
otterhere is offline
Old 07-28-2012, 04:43 PM   #4
1.5
Form>Function
1.5's Avatar
The install is not that hard you would probably surprise yourself with how capable you probably are.
If you pm me a price we can work something out.
1.5 is offline
Old 07-30-2012, 01:25 AM   #5
1.5
Form>Function
1.5's Avatar
Ttt
1.5 is offline
Old 07-30-2012, 12:29 PM   #6
otterhere
I am always surprised when I am capable of inflating my own tires without blowing them up in my own fact (I cannot do it myself; trust me on this)...
PM'd you; sorry for the breach of etiquette! And thanks.
Old 07-30-2012, 02:03 PM   #7
1.5
Form>Function
1.5's Avatar
replied
bump
1.5 is offline
Old 07-31-2012, 09:26 AM   #8
1.5
Form>Function
1.5's Avatar
still for sale
1.5 is offline
Old 08-01-2012, 12:15 PM   #9
1.5
Form>Function
1.5's Avatar
Bump
1.5 is offline
Old 08-01-2012, 03:10 PM   #10
ChitownY@Ris
ChitownY@Ris's Avatar
Drives: '07 Yaris Sedan
What would typical shop labor time be to get oem off and these babies on, 2 hrs?
ChitownY@Ris is offline
Old 08-01-2012, 10:16 PM   #11
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
I had a shop in O.C do it for 100$ installed took him 1 hour i was very happy and low to the ground... So 200 dollars isint bad for a droped yaris whats the rate on the springs again 1.5 bump for a good deal
g.q.vios is offline
Old 08-01-2012, 10:20 PM   #12
ChitownY@Ris
^^Cool.
Will 205/40/17 slicks be rubbing fender liner after the drop?
Old 08-02-2012, 09:39 AM   #13
1.5
Form>Function
1.5's Avatar
This is a pretty aggressive drop. My fronts were really low. I am running the stock 15s with 60 profile tires and I almost never rubbed. 17s may be different.
The spring rate is progressive.
Shop time should be about 2-3 hours for all four. Around 100-300 depending where you go, shop around.
1.5 is offline
Old 08-02-2012, 11:47 AM   #14
ChitownY@Ris
"Almost" never rubbed on 15s?
Ehh..Im lookin at some scraping symphony on 17s I gather. Bummer.
Stupid question here: What is the difference with coilovers and just lowering springs? I dont get it. You can make height adjustments with coilovers on the fly per say?
Old 08-02-2012, 12:13 PM   #15
1.5
Form>Function
1.5's Avatar
Yes. Springs replace the coil portion of your suspension without touching dampers. You have four springs and four dampers. The springs only will come with a predetermined drop and spring rate that cannot be adjusted.
Coilovers are fully adjustable race suspension. You will receive 4 dampers and 4 springs. In the rears the springs sit on a perch connected to your control arm while the dampers are an A style strut that sits seperately. The struts allow you to adjust spring preload and dampening (soft---> hard). The springs will then have an adjustable locking collar system allowing you to adjust ride height.
In the front your spings will sit around your dampers in a mcpherson style strut. This will attach to your hub and you chassis and will allow you to adjust spring preload or ride height by moving the three locking collars and you can adjust dampening as well. All seperate from each other.
The 17s might be fine. I mean almost like hitting a bump and having the front completely lift off the ground and come back down and then yes my tires did get pushed into my fender lining. I think that was the only time I rubbed. Freaking train tracks.
1.5 is offline
Old 08-02-2012, 12:56 PM   #16
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I think it is also worthy of note that most coilover setups run around $1k. you pay for adjustability.
BEEF is offline
Old 08-02-2012, 12:59 PM   #17
1.5
Form>Function
1.5's Avatar
Yes coilovers are much more expensive than springs alone. Also you can go wayyyy lower, forgot about that lol
1.5 is offline
Old 08-02-2012, 01:53 PM   #18
ChitownY@Ris
Wow. Yea smh..roads here in chi are porbably as nice as Baghdads..and I have to drive over train tracks like 5 times a day. I enjoy going dam near airborne over them like General Lee, and not hearing the slightest scrape.
Ive seen lowered Si's come to a dead stop over the same tracks, I'll nearly rear end them and have to whip around.
So that sucks..cuz I really like the lowered look. So I guess I gotta pay to play with the coilovers, if I want to stay rolling on 17s or 18s :(
KSport GT Springs 2 Inch drop all around YenOfIrrelevent Items for Sale by private party 27 05-02-2011 01:03 PM
KSPORT GT vs. Tanabe DF210 Lowering Springs bad_bwoy007 General Yaris / Vitz Discussion 1 04-12-2011 01:01 PM
KSport GT Springs? marlondog Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 03-01-2011 07:57 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
KSport springs too soft, need stiffer The Spectacle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 06-17-2009 01:39 AM
