Old 04-28-2010, 09:13 PM   #1
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
KSport GT Springs?
I was looking at installing some new spring, and I came across these KSPORT ones. They look like the Megan springs. Has anyone had experience with these? Good or bad?
http://www.corsportusa.com/store/cat...oducts_id=7436
marlondog is offline   Reply With Quote
Old 04-28-2010, 09:31 PM   #2
custom Lftback
custom Lftback's Avatar
Never heard of these before... They have a tanabe DF type of drop.
C-Lift
Old 04-28-2010, 09:34 PM   #3
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Most likely the same as the megans I have heard good things from the few people that have installed them.
Old 04-29-2010, 08:18 AM   #4
Only similarity to Megans that I can see are their orange colour.
Megans are linear, KSport progressive.
Megans drop 1.5" front and rear. KSport 1.6" front, 1.8" rear.
KSport spring rate not shown in link. Megans are 250 lbs front, 225 lbs rear.
Old 04-29-2010, 01:14 PM   #5
marlondog
marlondog's Avatar
So is "progressive" pc for "bouncy"? LOL!
Old 05-01-2010, 12:07 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
not necessarily. but it really doesn't give you any idea what is starts at and progresses to, now does it? weird, it should give you some sort of idea.
Colin Chapman disciple
Old 05-03-2010, 12:09 AM   #7
progressive rates mean that that farther the spring is compressed, the harder it gets
progressive rate springs will offer a more stock-like ride than firmer linear-rate springs
1.8 in the rear w/ 1,6 up front will look stupid if it sags a lot
Old 05-04-2010, 02:34 PM   #8
marlondog
marlondog's Avatar
I was able to get a guy on the phone, and he told me that the spring rate was "irrelevant" since they're springs and not coil-overs. He also told me that the springs were "30%" more aggressive than the stocks. Now how do those measure up to the aggressiveness of the Teins? Am I better off with these springs on the Tokico's or the stock struts?
Old 05-04-2010, 03:08 PM   #9
30% would make them about the same as Tanabe DFs. So with spring rate and drop being the same, these are probably orange Tanabes. They will be softer than Tein by a fair bit.
Old 05-04-2010, 03:42 PM   #10
marlondog
marlondog's Avatar
[QUOTE=WeeYari;468600]30% would make them about the same as Tanabe DFs. So with spring rate and drop being the same, these are probably orange Tanabes. They will be softer than Tein by a fair bit.[/QUO
So, are softer springs/stiff shocks(tokico's) the way to go for more comfort?
Old 05-04-2010, 05:34 PM   #11
markitect
Progressive springs are generally more comfortable because they are softer when the spring is extending from the normal ride height and compressing slightly, this is the motion most bumps, potholes, and other irregularities in the road cause, so for this it is soft, which generally means more comfortable.
Now when cornering hard it has the soft spring rate for the first bit and the body easily rolls, but then the stiffer rate comes into affect and reduces the additional amount of body roll that you will get, which make the cornering better.
markitect is offline   Reply With Quote
Old 03-01-2011, 07:57 PM   #12
YenOfIrrelevent
GreenRanger
Drives: 08 Yaris sedan
Just curious, its been almost a year since this post been active but has anybody tried these springs? If so, any issues? or pros and cons they want to share?
YenOfIrrelevent is offline   Reply With Quote
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
KSport springs too soft, need stiffer The Spectacle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 06-17-2009 01:39 AM
What springs should I get? Help! CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 01-26-2009 06:32 PM
