Old 09-11-2012, 09:18 PM   #1
A/F (Air/Fuel) Ratio
At idle and cruising/very light acceleration, my A/F ratio (according to my SG) stays around stochiometric (14.5), but when I floor it (only tried flooring it in 2nd gear starting from ~10mph and in 5th gear starting from ~32mph), it goes to 15-17. That means I'm running lean when I'm flooring it. It should be going <14, right? That means my engine isn't getting enough fuel when I'm flooring it (car doesn't bog or anything, and actually accelerates decently despite my wheel and tire combo being 41.3 lbs). Maybe it's because of where I am in the rpm band when I was flooring it? I was in city streets, so maybe that's why? I'll try flooring it on the freeway in 3rd gear the next time I'm on the freeway. There were a couple of times that it briefly went to 12.8.
I also noticed that if the loop remained closed, and when I was flooring it, that's when it went to 12.8. As soon as the loop went to open, the AF ratio went to 15-17.x.
Should I be concerned about this, or not because I'm basing it off the Scan Gauge, and I'm not too sure where it's getting its readings from.
Old 09-11-2012, 09:21 PM   #2
Mods include K&N SRI (intake pipe and engine side of heat shield wrapped in heat reflective material, if that makes a difference), 2.25" resonator-back exhaust, and NST CR-Lite crank pulley.
Old 09-11-2012, 09:29 PM   #3
More info, I'm using this X-Gauge
Air to Fuel Ratio for CANSF vehicles
GAUGE: A/F Ratio Bank 1 - Sensor 1
TXD: 07DF0124
RXF: 044145240000
RXD: 2808
MTH: 05B900800000
note: Ratio of Air to Fuel
Old 09-11-2012, 10:19 PM   #4
From my own experience the Scangauge shows you the "target" AFR of the ECU, not the actual ratio detected by the sensor. SO when it goes open-loop, there's no need for a target AFR and it may show a junk value...
Old 09-11-2012, 10:40 PM   #5
Thanks Thomas! So I'm going to assume that my car does go to being on the rich side when I floor it based on the very brief times it goes to 12.8 while still on a closed loop (so the ECU is making an effort to get the AF ratio there).
Old 09-11-2012, 10:51 PM   #6
Thomas is correct - That is target AFR, as opposed to actual AFR. I can read both with my YarGauge, and they are seldom in the same range. Also, the ScanGauge is pretty slow to poll the ECM, so the data lags quite a bit.
Old 09-11-2012, 11:00 PM   #7
So, with those number that I saw, my car is pretty normal then?
Old 09-11-2012, 11:01 PM   #8
Yes. They are normal for target. But, again that really doesn't mean much.
Old 09-11-2012, 11:25 PM   #9
Ah, I guess I'll just delete that gauge. Thanks, Thomas and Scott.
Old 09-12-2012, 08:05 AM   #10
yeah I stopped looking at it pretty quickly too... maybe on some other cars it shows more meaningful information, who knows...
And I don't know if your car does the same as mine did, but you could tell when it's running rich in open loop by the smell that starts to permeate the cabin :D
Old 09-12-2012, 12:50 PM   #11
lol, I thought that was the older car that was traveling in front of me when I was doing the testing. Yeah, I don't ever floor it in such a low rpm
Don't smell anything if I floor it on the freeway tho.
I NEED Boost... Opinions puh-lease Focus_Sh1ft Forced Induction Forum 551 02-08-2013 05:55 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
A/F Ratio (AFR) Kaotic Lazagna General Yaris / Vitz Discussion 4 02-05-2011 10:14 AM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
