Old 02-04-2011, 07:41 PM   #1
A/F Ratio (AFR)
Hey guys. Does anyone know if the AFR gauge on the SGII will work on the Yaris? I'm not sure if I'm plugging in the right one. I used the alternate AFR (general) under the ISO section: http://www.scangauge.com/support/pdfs/XGAUGE.pdf
Am I using the wrong codes? Nothing was displayed when I inputted the codes. Thanks in advanced.
Old 02-04-2011, 11:01 PM   #2
This is probably a proprietary PID of Toyota and wont be listed , in addition it probably is accessed through a different command code. My ELM327 gives me all the general PIDs but nothing from Toyota, I mean it can read them we just don't know how Toyota coded these PIDs
Correct. With my YarGauge I read AFR via a proprietary Toyota CAN ID that I reverse engineered from the TechStream tool.
Old 02-05-2011, 01:04 AM   #3
Dang, so it's not possible then with a SGII. Wishful thinking. lol. Thanks guys.
Old 02-05-2011, 01:04 AM   #4
What is a "PID" anyway?
Old 02-05-2011, 10:14 AM   #5
PID means "Parameter ID". The OEM proprietary ones require communication with different CAN bus IDs, which is the part that most aftermarket code readers don't have the ability to do.
Q about placement of wideband A/F sensor LtNoogie Performance Modifications 15 05-09-2012 12:03 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
VIDEO: My A/F readings according to my wideband PETERPOOP Forced Induction Forum 6 04-19-2009 01:39 PM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
AFR running extra rich at WOT? eTiMaGo Performance Modifications 15 03-10-2007 11:10 AM
