Old 04-09-2010, 04:02 PM   #1
rudiel
Drives: Black HB, 17" TenzoR rims
VVT-I setup
A friend of mine told me that he shortened a spring on the VVT-I on his car to activate it on lower rpms, is this possible? If so, can it damage the car in a short term? Thanks.
rudiel is offline   Reply With Quote
Old 04-09-2010, 04:06 PM   #2
vvt is always active....it doesnt "kick-in" at any rpm in particular
Old 04-09-2010, 04:24 PM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
It's also not controlled by spring tension, as a mechanical governor is. The mechanism for rotating the intake cam is controlled directly by the ECU, which opens and closes a hydraulic valve to actuate it for advancing or retarding the cam and gets feedback on the actual cam timing from the camshaft position sensor and crankshaft position sensor. This is why they call it VVT-i. "Variable Valve Timing with intelligence."
Old 04-09-2010, 08:15 PM   #4
rudiel
He gave me a ride a couple minutes ago to test his car. I notice an increase in acceleration at around 3,500 rpm. Now i am confused, you guys telling me it pretty much doesnt work and me feeling some gain on the car lol. Keep the comments going, they are appreciated.
Old 04-09-2010, 11:31 PM   #5
Dadombomb15
Dadombomb15's Avatar
Drives: 1996 Miata
maybe on a VVTL-i, but VVT-i engines don't have this "spring" you're talking about. On the VVTL-i, the spring you're talking about connects the slipper follower to the rocker arm. When the rpm's are above the set lift point, oil pressure slides a pin under each rocker arm switching it to the higher lobe of the camshaft giving it more lift for lengthier periods of time
VVTL-I engines have that extra kick but most of the time it isn't seen until far after 3500 rpm. my dad had an '07 Lotus Exige S for a while with the VVTL-i engine and damn did it move. then again it has a supercharger and an intercooler.
1996 Miata
Exterior: Aftermarket rims (on car when I bought it), aftermarket glass-window soft-top (also on car when bought)
Interior: Alpine H/U
Performance: Corksport "Drift" Cat-Back Exhaust, Hard Dog Ace Double Diagonal Roll Bar
Future (planned) mods: Intake, bumper turning light "induction" kit, better aftermarket wheels (lighter), light flywheel, upgraded clutch, racing seats, etc etc.
Dadombomb15 is offline   Reply With Quote
Old 04-10-2010, 08:11 PM   #6
ddongbap
Don't forget the car weighs 1 ounce.
Old 04-10-2010, 08:15 PM   #7
Dadombomb15
Drives: 1996 Miata
this is true haha
fun as all hell to drive, greatly miss it
1996 Miata
Old 04-10-2010, 03:40 PM   #8
rudiel
Its a VVT-I. Tis is weird! lol
Old 04-10-2010, 07:33 PM   #9
Dadombomb15
Drives: 1996 Miata
is the car bone stock?
1996 Miata
Old 04-10-2010, 11:55 PM   #10
rudiel
CAI, exhaust, fuel regulator i believe
Old 04-10-2010, 11:57 PM   #11
rudiel
ddong u an idiot lol
Old 04-11-2010, 01:32 AM   #12
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
El VVT-I en los 1nz NO activa. Si se siente mas fuerte a ciertas revoluciones pero NO es un V-Tec o VVTL-i. So NO activa. Veta a dar una vuelta en tu carro ventanas arriba y aire apagado y pisalo en una recta, vas a sentir como por las 5,550rpm "activa" pero NO activa na' es q se siente mas.
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 04-10-2010, 07:56 PM   #13
look at a dyno of a stock Yaris. You'll see why you feel something at 3500 rpm. It's not necessarily the VVT-i
Old 04-10-2010, 08:10 PM   #14
ddongbap
VVT-I JUST KICKED IN YO.
Old 04-12-2010, 01:45 AM   #15
hondakiller99
Drives: 05 Scion xA
um , isnt vvt-i activated 24/7 and ran off the throttle pos. sensor and retards when ur not beating the piss out of it and advances when u have the pedal to the asphalt?
hondakiller99 is offline   Reply With Quote
Old 08-03-2010, 09:51 PM   #16
victorcr
victorcr's Avatar
Drives: YARIS T-SPORT
Send a message via MSN to victorcr
yaris es toda caminan rico
victorcr is offline   Reply With Quote
Old 08-03-2010, 09:52 PM   #17
victorcr
victorcr's Avatar
Si Se Puede poner una Trabajar Mejor El VVT -i aqui en Costa Rica lo Hacen vale 1000 dolares Trabajo de El
rpm, vvt-i, vvti
My suspension setup: Breakfast Blend for the angry panda Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 07-26-2010 04:56 PM
New "milder" Setup Loren Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 04-26-2010 11:08 AM
N/A setup Maitre_Te_Te Performance Modifications 22 12-07-2009 04:24 AM
At what RPM VVT should be activated? Parmas Performance Modifications 30 11-19-2009 08:40 PM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 06:52 PM
