Old 10-05-2009, 08:49 PM   #1
Maitre_Te_Te
Drives: Yaris 08
N/A setup
Il want to do this tread for compare all N/A setup.
My yaris setup:
1zz TB
1zz injector
Borla axel back ( TRD parts )
Home made 2.5 inchs cold air intake
I want to install a free flow catalitic convertor and a 2 inchs exhaust
16 inchs DAI light wight
Eiback coil spring
Trd rear sway bar
I need some idea for my project.
Tanks!
Maitre_Te_Te is offline   Reply With Quote
Old 10-05-2009, 08:57 PM   #2
2.5" intake is too big, won't work with the MAF
forget the axleback and get a custom-made exhaust from the resonator back. the cats and resonator are 2" thru and the exhaust shrinks to 1.75" after the resonator. i had mine replaced last week....its worth the effort. skip the high flow cat, not worth the time/effort.
get a dc header because all the other headers are junk
nst underdrive crank pulley and lightweight water pump and alternator
1zz throttle body is ok
1zz injectors not likely req'd for n/a setup
wait for cali_yaris's intake manifold
get lightweight 15" rims, skip the 16's
Old 10-05-2009, 09:07 PM   #3
Maitre_Te_Te
Drives: Yaris 08
Tanks, but for de 2.5 intake, I have buy a fiting for this. I ajust the diameter for the MAF!
http://www.sfxperformance.com/parts/SPT9405.htm
For the cat hi flow, this is because I got one at the past and it is in my room!
tanks for your help!
Old 10-05-2009, 09:46 PM   #4
ruimond
Drives: Yaris YR
Haha i didn't realise the piping for the cat and resonator were 2" already. Only remembered the exhaust place saying that the piping that they cut off from mid to muffler was 1.75". Guess that's good that i got 2" piping down then.
Hehe learnt some new info.
Old 10-05-2009, 10:27 PM   #5
jouna
jouna's Avatar
Drives: jdm yaris sedan
wat i did is from the maf to the throttel. is put 2 inch tube and from the maf to the fog light 3 inches is kind of wat the aem v2 intake does
vvti bregao!
jouna is offline   Reply With Quote
Old 10-05-2009, 11:08 PM   #6
posaunemeister
Drives: 2008 Yaris S LB - MM
About 3 or 4 weeks ago, I tried to do a DIY axleback and failed miserable, because I read many times on the forum that our stock axleback exhaust pipe diameter was 1.75", but it's actually smaller than that. I measured a 1 3/8" ID for the piping just before it enters the muffler. I have an '08 Yaris 'S', but It should not be different than any other Yaris hatchback.
posaunemeister is offline   Reply With Quote
Old 10-05-2009, 11:12 PM   #7
Maitre_Te_Te
Drives: Yaris 08
The 1nz-fe have a 11:1 compression ratio but the prius have a 13:1 compression ratio. What is the different? Piston or culass (head) ...
Because I think that for the N/A setup, if we boost the compression ratio, we can win 10 hp... maybe!?!?
Old 10-05-2009, 11:55 PM   #8
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
+2
Old 10-06-2009, 03:37 PM   #9
t0m4s
1NZ-FE
t0m4s's Avatar
Drives: Yaris Seddan 08
cali_yaris is doing an intake manifold???? where are the updates for this?
DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
t0m4s is offline   Reply With Quote
Old 10-06-2009, 03:48 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
no...
Old 10-06-2009, 03:52 PM   #11
http://www.microimageonline.com/foru...ni-thread.html
Old 10-06-2009, 08:10 PM   #12
crxgames
Drives: 2005 Scion xB
Prius has a 1nz-fxe which has a completely different style head for efficiency. Though, you are correct that it has a 13:1 compression ratio. The lower end is also suppose to be the same as the 1nz-fe. Your best bet would be to do a 1nz-fxe bottom end with an adapted 1nz-fe head. There is a thread with a lot of details on the possibilities of this somewhere on clubxb.com, though it has not been done yet.
I personally wanna see this done, I just don't have the money to do it right now since I'm building an S13.
crxgames is offline   Reply With Quote
Old 10-06-2009, 08:16 PM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
no, the prius bottom end is nothing special.
Old 10-06-2009, 08:30 PM   #14
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Tamago didn't you look up the piston part number and they were different?
Old 10-06-2009, 08:42 PM   #15
crxgames
Very true. I just looked everything back up.
The extra compression appears to come from the different pistons, no? Someone on scionlife saw gains with 11:1 pistons and an emanage tune.
http://scionlife.com/forums/showthread.php?t=65124
Old 10-06-2009, 11:03 PM   #16
Maitre_Te_Te
Drives: Yaris 08
Ho yeah, I have read this. 13 WHP with prius piston and e-menage. I will look for this !!!!!
Old 10-06-2009, 11:55 PM   #17
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
no...
Explain please. i was under the impression higher compresion = more air/fuel/HP
Old 12-06-2009, 07:41 AM   #18
advocate
Drives: car
Barber what do you think about getting a custom exhaust done from the catback instead of the resonator back? Why did you recommend to the OP that he start after the resonator?
Is there any other exhaust piping that needs to be increased to 2" besides the resonator-to-muffler piping?
Also if you're running an axleback already would it be easy to go to a muffler shop and have them convert from an axleback to a catback?
My suspension setup: Breakfast Blend for the angry panda Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 07-26-2010 03:56 PM
Warranty Information for US Yaris Owners AdeJong 03 General Yaris / Vitz Discussion 4 09-19-2009 10:14 PM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 05:52 PM
good speaker setup. ryota In Car Entertainment + Electronics (audio / video / alarm) 18 08-08-2009 07:46 PM
Suspension Setup Question Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 04-28-2007 02:05 PM
