Originally Posted by crxgames
Prius has a 1nz-fxe which has a completely different style head for efficiency. Though, you are correct that it has a 13:1 compression ratio. The lower end is also suppose to be the same as the 1nz-fe. Your best bet would be to do a 1nz-fxe bottom end with an adapted 1nz-fe head. There is a thread with a lot of details on the possibilities of this somewhere on clubxb.com, though it has not been done yet.
I personally wanna see this done, I just don't have the money to do it right now since I'm building an S13.
no, the prius bottom end is nothing special.
