![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
Tools to change front and rear suspension
Can someone list the size of tools in order change front and rear suspension. Also, take off stock shock attachments in to Tein.
Very appreciated your help and information! Happy New Year! |
All black everything.
Drives: '09 5dr All black. Join Date: Dec 2011
Check out the DO IT YOURSELF section of the forum, TONS of helpful stuff.
Like the link below that has exactly what you are looking for: http://www.yarisworld.com/forums/showthread.php?t=1096 |
YPod09, Thanks for the link! I am going to try install the Tein basic this weekend.
2ZR swap. DO IT! Ask how!
If you are keeping the stock shocks, you MUST have the spring compressors to safely remove the spring retaining plates. You should also have access to a decent quality impact wrench, an 18" or longer breaker bar, and all of the tools listed in the guide/service manual.
Also, a decent set of jackstands is the bare minimum you need to safely lift the vehicle. Do NOT use just the emergency jack! If you have access to a vehicle lift, that's the best tool to use. |
Thanks all for the advice! I am plan buy all the hardware and not bother to take any parts from the stock suspension. I believe this way will make my life easier. I notice it will be cost a bit but I am going to do it myself. Looking forward pushing hard in the corner.
This is what I did with my front springs/shocks when I put on Tokico blues and Tien S-techs, so now it's just a modular swap. You will need to use a press to install the bearings on the retainer plate, but everything else is just hand tools.
Crankyoldman, in order to press the bearing on the retainer plate. What kind the tool I have to prepare. Its okay rent it from AutoZone.
I am try to get all the information and get it done in the weekend. Yaris is my daily driven vehicle. |
To press the bearing correctly, you need an arbor or hydraulic press. I have access to a few different sizes at work and at school, so I didn't need to buy one. I don't see them available from AutoZone for rental, but you can probably go to a mechanic and ask them to do it for you. It only takes a few seconds, so they may even do it for free.
I am going to get everything done first before making a move. I dont wanna end up missing of hold up something. Thanks for the advice!
| lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 08:47 AM |
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
