View Poll Results: Which rear sway bar for a daily driver?
TRD 11 78.57%
Whiteline 3 21.43%
Ultra Racing 0 0%
Voters: 14. You may not vote on this poll
Old 02-22-2013, 02:59 PM   #1
Airswoosh1
Drives: Toyota Tercel
Which Rear Sway Bar??
My friend recently picked up an '08 Yaris sedan and after driving it and being a passenger in it, I noticed the understeer it suffers from. Car is completely stock, and while I am more than aware wheels/tires & springs/shocks would really help as well, she rather not change the look of the car, so rear sway bar is where we are. And after a little reading, it seems as though there are basically three rear sway bar options: TRD, Whiteline, and UR.
Car won't be used for anything but as a DD, just looking for a little more stability. Should the TRD be adequate? Or might as well spend the extra $50 for the Whiteline?
What do you guys think?
Airswoosh1 is offline   Reply With Quote
Old 02-22-2013, 03:32 PM   #2
Whiteline is adjustable, you can set it at your preferred stiffness.
TRD/UR are simpler and identical to each other, but the UR is less expensive.
Old 02-22-2013, 03:46 PM   #3
Airswoosh1
I have seen that the Whiteline is adjustable...that is a plus...
I thought I read that the UR was thicker, no? I haven't seen the UR for very cheap, and doesn't seem to be as readily available (you guys don't seem to have it in stock). It seems I can get the TRD down at Carson Toyota for just a shade over $160.
Complexity really isn't an issue, I've seen how both styles mount, and installation looks to be a heck of a lot easier than the Whiteline RSB I put on my Tercel.
EDIT: I see there are two different size UR bars.
Old 02-22-2013, 03:55 PM   #4
For a DD, and with it easily available to you, the TRD is sufficient. No need for the stiffer UR in her situation.
Old 02-22-2013, 04:21 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
having seen the whiteline first hand, i think it is a cool little design. Plus it has 2 settings, which is nice if you don't like the first setting.
I have a natural aversion to trd, only because nothing they make is made themselves, it is all rebranded. And it is expensive.
Colin Chapman disciple
Old 02-22-2013, 06:06 PM   #6
Airswoosh1
True, they are typically rebranded parts, but usually reputable companies. Who is the original manufacturer of the Yaris TRD RSB? And I agree, usually they are overpriced, which is why I find it odd that I have found it to be the least expensive of the three.
Old 02-22-2013, 06:56 PM   #7
UberSilver
UberSilver's Avatar
My vote was/is for the WL, as I feel they put a little more R&D into it.
Works great on my Yaris.
Old 02-22-2013, 07:36 PM   #8
Airswoosh1
The one negative I foresee with the Whiteline is the necessity to periodically re-lube the poly bushings. On my car, it wouldn't matter, but on anyone else's, I rather not add something that would require maintenance (albeit minor).
Old 02-22-2013, 08:19 PM   #9
racerb
I'm running the Ultra Racing 23mm on my auto-x Yaris, but if I can build an earlier car for B-Spec, it's TRD all the way! Sparks Toyota has a great deal on the TRD unit right now....http://www.trdsparks.com/displaypart...&parts_id=1374
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-22-2013, 08:21 PM   #10
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Doesn't the Trd rsb cost less than the white line? Sparks Toyota sells the trd rsb for 161 delivered
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 02-22-2013, 08:28 PM   #11
racerb
I can actuall get the TRD bar for the sell price, but then again I'm less than an hour away from Sparks!!
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 02-22-2013, 11:56 PM   #12
Airswoosh1
Why am I not seeing it for that low? With shipping, it's about $175 .
Old 02-23-2013, 02:36 AM   #13
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
There's a trd on ebay up for auction at $67 so far with less than2 days to go.
http://www.ebay.com/itm/Toyota-Yaris...dd65df&vxp=mtr
Old 02-22-2013, 09:50 PM   #14
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
hot cheetos & takis swaybar
Old 02-22-2013, 10:41 PM   #15
tooter
play every day
tooter's Avatar
I like the TRD because it tucks up inside the crossmember...
Old 02-23-2013, 03:49 AM   #16
Airswoosh1
Yeah, I had seen that one, I've got my eye on it. Thanks.
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
WTB: Rear sway bar weedtank Willing to Buy by private party 4 02-08-2012 01:50 AM
Rear sway bar snow clearance? CrankyOldMan Performance Modifications 19 09-15-2011 01:40 AM
FS: TRD rear sway bar 19mm brand new in box hksir Items for Sale by private party 7 02-12-2011 08:07 PM
Is the TRD rear sway bar a worthwhile upgrade? YellowJolt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 07-15-2009 08:07 AM
