Old 10-18-2012, 04:37 AM   #1
yariseggvvti
Drives: Yaris Hatchieback
xA or xD front sway bar fit in to 07 Yaris
Dose any one try to up grade front way bar with this.
Scion xA/xB 2004-2007 Hotchkis Comp. Swaybar Set (HotchkisSwayBarsxAxB22412)
Scion xA/xB 2004-2007 Hotchkis Competition Swaybar Set
Model Number: 22414
Applications:
2004-2007 Scion xA
2004-2007 Scion xB
Gain increased stability and control of your Scion xA / xB with the Hotchkis Sport Suspension competition sway bar package. Our replacement front and bolt-on rear sway bars give the xA / xB precise, balanced handling especially when carrying addition passengers. Comfortable ride quality is maintained. Additional benefit of tire and wheel upgrades will be felt due to the increased front/rear roll stiffness of our sport sway bar package. This easy to install package is well engineered for maximum performance, is powdercoated gloss red for improved durability and comes complete with installation hardware. For additional performance try our sport lowering springs #19412 for the ultimate in Scion handling and comfortable ride quality.
Features:
•Front sway bar-lightweight, durable 1 1/8” (29mm) tubular steel
25% stiffer than stock sway bar - (355 lbs./in)
Greasable polyurethane bushings with cad. plated sway bar brackets
•Rear sway bar-lightweight, durable 15/16” (24mm) tubular steel
Rear bar is rigidly mounted (bolt-on) (250 lbs/in.) (No stock rear sway bar to compare %)
CNC machined billet steel ends are TIG welded to rear bar
Premium installation hardware included
•Finished in durable gloss red powdercoating
Benefits:
•Vehicle in stock form showed excessive roll and understeer
•Replaces OEM front stabilizer bar and adds a rear stabilizer bar
•Hotchkis sport swabars have increased stiffness, which…
Reduces Body Roll
Improves High Speed Stability and control
Increases Traction During Cornering
yariseggvvti is offline   Reply With Quote
Old 10-29-2012, 09:47 PM   #2
smofskra
smofskra's Avatar
Drives: 08 Flint Mica Sedan
Send a message via MSN to smofskra Send a message via Yahoo to smofskra
why not buy one made for a yaris? there are plenty of them out there
"Chrome wont get you home"
smofskra is offline   Reply With Quote
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
