Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
can it be this easy to make a "custom" turbo kit?
can it be this easy to make a turbo kit? roughly $1634
how good is the t3/t4 turbo? http://www.ebay.com/itm/UNIVERSAL-T3...9a7e48&vxp=mtr http://shop.microimageonline.com/1NZ...-tmani-nwg.htm http://shop.microimageonline.com/AEM...er-30-1910.htm http://shop.microimageonline.com/Boo...ss-BS-001Y.htm of course no turbo kit is good unless you get some parts from Micro Image
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#2 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Mr. 155 and climbing
Personally I would not buy one of these, but that is just me.
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
Get the zage kit from MI and call it a day. Going custom is not as difficult as it use to be there are many diy on it.
sure i suppose i could do that and add the wiring harness and AEM FIC to bring up to $2488 or see if i can build a kit that works and has red silicone instead of the blue ones especially if the car is red, the blue might clash a little. and with as much feed back and information on going turbo there is on this forum and the MI forum it should be fairly easy to get together and running good. not to mention that i would also have to hit up Garm for low compression pistons and H or I beam connecting rods. so save the 800 or so difference and Invest it into the bottom end.
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
It concerns me that this turbo doesnt have a coolant line (only says oil cooled)
IMO this would be a good kit to build off of. would recommend a better turbo as well and you will probably will need more I/C lines as well as i would be hesitant to use the no-name BOV and wastegate actuator
#7 | |
#8 | |
A Tial Wastegate for example is 200+ bucks all on its own let alone and then a solid BOV is another 200+. And let's not forget the boost controller they have which as well you have no idea who manufactures. Just stay away from it and don't have any regrets.
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
I can't say I wouldn't recommend it, but realize there is A LOT of custom fabrication that will still be needed. Unless you can do it yourself, you're going to be paying for additional parts AND labor. That would likely push it past the point of being more cost effective than a kit, but I could be wrong.
Things to consider: 1) Custom manifold. It's going to need a flange for an external wastegate by the looks of it. 2) Custom downpipe. 3) Personally, I wouldn't want a turbo that isn't water cooled. I also think T3/T4 is a bit overkill for our engine (unless you're building the bottom end). 4) Additional intercolor piping. 5) You'll have to tap the block for oil drain. I agree with avoiding no-name brand parts too. My bov I used was a knockoff, and just look at how much trouble that caused me... |
Here's the part Garm is gonna like but end of the day its true.
The Zage kit you get good quality starter products complete and ready to install. also if there is any problem with the kit, Microimage will back you up 100% the way.
#11 | |
#12 | |
Having customer service > not having it. There really is no reason to not use Zage if you're not planning on a big build. Keep in mind turbo kits for most other cars run $3k+ |
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
I do have an excel sheet with most of the parts you will need for a full turbo kit, $1634 seems a bit low.
#14 |
can i get a copy of that, should be interesting to look at and see what all i'm missing from the original post. I know there are a few things missing from the OP and i know that in order to make a good system low compression pistons, upgraded connecting rods, turbo timer, quality blow off valves, and probably an upgraded fuel system as well.
#15 | |
Couldn't find the final version, but will look for it. (it wasn't completed though) Last edited by hw6515; 03-19-2013 at 05:03 PM. |
#16 | |
#17 |
Can anyone with first hand knowledge post why those eBay turbos are so bad?
I think pimp my yaris has been for like 2 years with one of this turbos and has not reported any issues with it. OP, tell me if you prefer i ask this question on my own thread. |
#18 |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
They are simply knock -offs. Materials are low quality, balancing methods are primitive, no R&D. One who supports knock -off performance parts, is one who is making the aftermarket performance industry go south.
Ptuning.com |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Plan to install hks turbo kit on 1szfe | Faraz_Shaikh | Forced Induction Forum | 5 | 10-19-2010 11:00 AM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 15 | 06-09-2007 01:24 AM |
| Garrett Turbo kit | elsteverino889 | Forced Induction Forum | 24 | 04-20-2007 10:27 AM |
| ZPI to produce yaris turbo kit and exhaust | turboyaris | Forced Induction Forum | 30 | 04-04-2007 02:10 PM |
