Suspension Problems
So, my car has almost reached 100k and I'm finally starting to see some issues with it, its been perfect up to this point.
The other day, I noticed while turning my suspension was making a creeking / popping noise. It continued doing this for about a day and a half then somewhat went away. Today driving from lunch, my steering wheel starting shaking back and and forth steadily, not a lot of small vibration, just consistently turning back and forth while driving pretty slow (about 20 MPH) I plan on going and getting it checked out, just wanted to see if anyone here had some insight as to what it might be. Thanks!
I noticed your car is lowered my guess would be a strut mount/bearing that could cause the creaking popping however it wouldn't really cause a steering wheel vibration at low speeds. It could be a worn out tie rod end usually they go bad in slow progression though they arent just good one day and totally worn the next day. Either way i would get it check out by a shop soon as possible because its most likely going to get worse and could potential be a safety issue.
The creaking/popping could also be the broken control arm bolt issue:
http://www.yarisworld.com/forums/showthread.php?t=27658
#4 | |
![]() ![]() Drives: 2012 Yaris SE 5MT Join Date: May 2012
Get it to a dealer asap!! |
| follow up on 2010 yaris problems + more problems | heavenswaitin | DIY / Maintenance / Service | 18 | 09-03-2013 04:47 PM |
| Question about VITZ RS suspension and Yaris / Vitz (Non-RS) | seechoong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 04-04-2013 03:47 AM |
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 10:26 PM |
| NSW Proposed Suspension Restrictions | Bella | Australia | 0 | 09-22-2010 02:51 AM |
| Tein Basic Compact Suspension for SALE!! | 33lam | Australia | 14 | 04-17-2010 09:24 PM |
