![]() Drives: Toyota Vios 2012 Join Date: Jun 2013
Changing Map Light Bulb
I want to change my map lights bulb but there is no step-by-step instruction on the car's manual. Is there anyone who already change these? I don't want to change it without a correct instructions because it might broke something. Thanks in advance.
![]() ![]() Drives: Yaris Sedan Join Date: Apr 2012
I assume this is a US Yaris 08-12. Pry one of the clear covers from the middle with a flathead screw driver. It takes T10/194/168 bulbs, pull out the bulb. push the new one in (polarity does not matter).
Let's assume u took out the driver's side. to put on the cover, u would slide in the left side of the cover first, then push the right side of the cover to lock it into the pegs. |
Clarenceie is correct. I would just add that you should be sure to pry the lens (cover) out "gently".
| Bulb Replacement Guide (led Sizes) | theFEVA | Cosmetic Modifications (Exterior/Interior) | 113 | 02-28-2017 01:02 PM |
| Light bulb questions | Yaris_80 | DIY / Maintenance / Service | 4 | 07-16-2013 01:36 PM |
| Light Bulb Numbers For Interior Illumination | privateyeblckbx | Cosmetic Modifications (Exterior/Interior) | 0 | 05-16-2010 05:59 AM |
| anyway of taking out the abs light bulb? | SweetRS | DIY / Maintenance / Service | 2 | 03-13-2009 09:24 PM |
| MAP LIGHT | drell42 | Cosmetic Modifications (Exterior/Interior) | 2 | 05-21-2007 08:30 PM |
