Old 03-13-2009, 06:58 PM   #1
SweetRS
Drives: 2006 Yaris Rs
anyway of taking out the abs light bulb?
SweetRS is offline   Reply With Quote
Old 03-13-2009, 07:33 PM   #2
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
from the gauge cluster? maybe if it is not soldered in....
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-13-2009, 08:24 PM   #3
It's an LED, not a bulb, so you'd have to desolder it, or just pull the face off of the cluster and put a small piece of electrical tape over it.
I've also put a dot of permanent black marker on a surface mount LED's lens, to make it be not so bright, but still visible.
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 02:59 PM
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
xenon hid light bulb lilman717 Cosmetic Modifications (Exterior/Interior) 7 12-19-2008 08:07 PM
The right fog light bulb exploded and cracked the lense vacantj DIY / Maintenance / Service 1 08-01-2007 04:07 AM
