Old 06-13-2013, 01:00 PM   #1
peewee1
PEEWEE1
peewee1's Avatar
Drives: 2009 yaris s sedan
re-learning ecm?
Am I to understand that there is a way to make my ecm (the cars computer) re learn my driving habits? My 2009 Yaris S is a used vehicle and I have no idea how it was driven by the previous owner. I would like to have my car react to my habits not some lead foot!!!
peewee1 is offline   Reply With Quote
Old 06-13-2013, 02:06 PM   #2
The ECM can be made to re-learn the short term fuel trims, by simply disconnecting the negative battery terminal for a couple of minutes. As far as re-learning shifting patterns relative to your driving style - That requires resetting the automatic transmission control within the ECM via the Toyota TechStream tool. I did that on my 09 about two weeks after I installed my Blitz Supercharger and noticed that once I did so the tranny shift points seemed better relative to the extra boost from the S/C.
Old 07-17-2013, 10:30 PM   #3
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Can we use the same tool to create a 'sport mode' type of thing, where it will keeps the rev high?
caineroad is offline   Reply With Quote
Old 07-17-2013, 11:48 PM   #4
To some extent yes. If you reset the ECM's tranny control and then drive it like you stole it the ECM should learn that shifting behavior.
Old 07-17-2013, 11:59 PM   #5
caineroad
caineroad's Avatar
I see... I wonder if is it possible to individually set each gear shift point using the techstream tool? or the minimum speed for cruise control?
Old 07-18-2013, 07:04 AM   #6
No
Old 07-19-2013, 12:33 AM   #7
jcboy
Drives: Sedan 07
curious question CTScott, is it good for a manual tranny? I drive normally, but because of inconsistent fuel economy figures sometimes on a drive it like a stole it manner (some nights/highway).
I still can't figure out the best shifting points that will keep fuel economy figures high. the manual states the best shift points but they're usually on 3k rpm point. are those accurate? or should i unplug the negative terminal then drive normal 100% (or for most of the time)?
Old 07-19-2013, 09:14 AM   #8
The tranny related reset is purely for the AT. If you do a throttle body and/or MAF cleaning, doing the battery disconnect reset is a good idea to reset the fuel trims.
Old 07-20-2013, 03:45 AM   #9
jcboy
Drives: Sedan 07
oh i see. so i guess it's the inconsistent city traffic that i don't notice anymore (been living and driving in the city for more than a decade). sigh.
thanks a bunch scott! i wish there was a filipino version of you here. :)
DIY - How to remove or insert a pin on the ECM Connector A21 CTScott DIY / Maintenance / Service 6 05-21-2024 01:29 PM
WTB: ECM connectors(car side) + ECM male connector(ECM side) mazilla Willing to Buy by private party 5 10-03-2011 10:25 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 04:54 PM
ecm controller yaris9876 DIY / Maintenance / Service 0 05-26-2010 09:06 PM
Yaris has a learning ecu? YogiYaris Performance Modifications 9 05-30-2007 08:03 PM
