Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 10-02-2011, 05:11 PM   #1
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
WTB: ECM connectors(car side) + ECM male connector(ECM side)
Just thought I'd throw this out here and see if anybody has a the parts I need to have a plug and play made for my Emanage Ultimate. 500.00 from Boomslang is a little over the top IMO(that's my opinion, it's not open to debate, so save your brain power and finger strength for something else).
I also cannot just splice them in since I'm red/green color deficient so it makes it impossible for me to see some of the subtle differences in some of the wire colors...I can get away with a lot, but that's just too many wires and too many chances to make a mistake.
PM me with what you have.
THANKS!!
-Type 07 FFL-
My odometer 03/11
mazilla is offline
Old 10-03-2011, 05:49 PM   #2
Jason@SportsCar
Good luck... When we had our PNP made (not by Boomslang) we were told the connectors are crazy expensive and not easy to source.
Jason@SportsCar is offline
Old 10-03-2011, 06:29 PM   #3
The female side comes off of an engine harness and the male side comes off of an ECM.
ECMs can be purchased for as little as $25 if you hit them right on eBay or at a junkyard (I have never paid more than $50 for an ECM {and, yes I have bought about half a dozen over time for various experiments}).
Harnesses are trickier. There are two separate engine harnesses (terminating to each of the two ECM connectors). I caught one set off eBay for $80 each, but typically people ask $150 to $300 each for them. I bought one of the large connectors (the smaller one was already gone) from a junkyard that let me harvest it myself for $20.
There is actually a ton of labor in making the harness, since there are 36 connections on connector A21 and 63 on Connector C20. The AEM F/IC only makes a total of 23 connections to the harness, so to make a plug and play harness you solder 198 connections (63+63+36+36) to make the Male to Female "extension cable" and then 23 to then connect the F/IC to it.
So, after working with Adrian's Boomslang, I would say that the plug and play is nice, but is an incredible amount of labor in comparison to making 23 connections.
As for the colorblind piece; I never trust wire colors, but rather always follow pin position.
Edit: Actually 99, not 198 as long as you harvest the female side with enough wire still attached...
CTScott is offline
Old 10-03-2011, 06:52 PM   #4
mazilla
advocatus diaboli
mazilla's Avatar
Oh, just 99?
In that case....
I didn't think about using the pin location vs wire color, is there a diagram somewhere that I can use to determine what's what? If it saves that much work and money, and I can do it myself without having to guess it's probably the best route...it would speed up my install considerably.
On the other hand I did find the components I need locally, if I had an idea of the labor cost I could more readily determine which direction I should take. Hopefully a wise and powerful electronic wizard will send me a PM with an estimate.
-Type 07 FFL-
My odometer 03/11
mazilla is offline
Old 10-03-2011, 07:54 PM   #5
This should help quite a bit:
Yaris ECM.pdf
CTScott is offline
Old 10-03-2011, 09:25 PM   #6
mazilla
advocatus diaboli
mazilla's Avatar
Attachment 43971
Indeed, thank you very much.
-Type 07 FFL-
My odometer 03/11
mazilla is offline
