![]() Drives: Toyota Yaris SR 2008 Join Date: Aug 2012
2008 UK 5 door Yaris 1.3 TR Steering wheel/pad.
Hi
Wonder if anyone can help ? I am trying to remove the steering wheel on my 2008 UK RH drive Yaris TR and cannot see any torx screws under the wheel to undo to release the pad. There is one hole underneath the horn symbol but no screw under it. I am stumped ! Wonder if anyone can help? Thanks John |
Does it not have the two screws on the sides of the rear portion of the steering wheel?
Hi CT,
Unfortunately no it hasn't, there is only 1 hole and it is underneath where the horn symbol is on the rear portion of the steering wheel and there is no screw underneath it. I have managed to prise the rear portion cover of the steering wheel back and there are no screws visible, but I can see a spring clip on either side under the airbag. Could these be the holders for the airbag/steering pad ?. Thank for reply and any help. Cheers John PS The car is a UK RH drive Yaris TR 1.3 2008. |
#4 | |
Yes I would say you are right, are they easy to remove and replace ?
Cheers John |
On the 2012+ US ones that have this style, there is a small plastic trim piece on the side of the rear cover that pops off. That gives you the ability to see under the airbag and to reach in to release those clips.
There is no detachable trim piece on my cover, trust me to have the most awkward one !!!
I will have to pull the rear cover back and try to release the clips that way. Cheers John |
With the ones that don't have the side cover, but do have the hole on the edge of the pad, you are supposed in insert a tool into that hole to release the tab latch on that end. Once you do, you can lift the pad enough to get at the other latches.
Hi again CT,
Now you have explained the procedure I removed the airbag and wheel in 5 minutes and fitted the new clockspring. Many thanks again for your advice. Cheers John |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| Steering column compatibility between Euro Yaris and US Yaris | Micropurchase | Third Gen Yaris General Discussion | 19 | 09-17-2012 12:00 PM |
| 2008 5 door Yaris 1.3 TR rear hub replacement. | JOHNVW | DIY / Maintenance / Service | 4 | 09-16-2012 10:14 PM |
| Steering wander, adjusting EPS assist | Snubba | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 05-22-2012 05:39 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 10:16 AM |
