Old 09-15-2012, 10:25 AM   #1
JOHNVW
Drives: Toyota Yaris SR 2008
2008 5 door Yaris 1.3 TR rear hub replacement.
Hi,
I have a 2008 5 door Yaris 1.3 TR hatchback with 42, 000 miles on the clock.
I have recently noticed a droning noise which seems to be coming from the o/s/r of the car, I jacked up the car and spun the wheels and the offside rear feels rough compared to the others so I suspect it is this wheel bearing that is on the way out.
There is a wire attached to the hub which I guess is the ABS connection.
From what I can gather you replace the hub assembly rather than just the bearing, is this correct ?.
Has anyone done one these ? It looks like it's held to the rear suspension with 4 bolts so wonder if it is a straight forward job ?.
I have seen a few of these hub assemblies on E bay at various prices.
Thank you in advance for any help.
All the best
John
JOHNVW is offline   Reply With Quote
Old 09-15-2012, 03:37 PM   #2
The rear hub is relatively easy to change. You just need to located one that is ABS equipped as well:
Old 09-16-2012, 11:34 AM   #3
JOHNVW
Hi,
Many thanks for your reply and for the diagram.
Yes it doesn't' look too difficult, I will locate a hub with ABS and have a go.
Thanks again
John
Old 09-16-2012, 01:08 PM   #4
Geoff Peace
Drives: Yaris 1.33 litre 2011
Attachment 48455
I could not help but notice that the ABS sensor is listed as a non reuseable part. Surely one is not expected to buy an ABS sensor due to a failed wheel bearing! Or have I missed something? Could you please explain?
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 09-16-2012, 10:14 PM   #5
That is interesting that such a crazy expensive part is considered non-reusable. I have no idea as to why Toyota did that, unless the part gets damaged in the process of removing it from the hub.
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
New 2008 LB with Front and Rear skirt! GabL Canada 7 10-01-2007 02:29 PM
