![]() ![]() Drives: 09 Yaris Hatchback Join Date: Oct 2014
Oil Return on upper oil pan sub assembly
I found this here on the forum and I have a few questions.
how many inches from the bottom of the oil pan assembly to the desired spot for the oil return? also what size of an fitting is the best for oil return coming out of the oil pan assembly? My T28 turbo oil feed line came damaged and I need to replace it, Do you guys have any good places to buy oil feed and return lines?
uhh.. like this..?
You want to drop the oil it above the oil level, rather than feeding it into the bottom of the oil pan. Where that arrow points to is just about right to be above the oil level (About 3" above the oil pan gasket). I would use a -AN type bulkhead fitting of the proper size for the turbo's output oil fitting.
JEGS and Summit Racing carry oil lines and fittings at reasonable prices.
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
If I remembered I used a 9/16" bit and a 3/8 npt fitting with a 5/8" barb end.
That is something you might have to determine for yourself. Avoid any kinks in the line to prevent oil from puddling and creating an oil flow restriction.
With fluids and particularly viscous ones you want to avoid 90 degree turn, unless that have a wide radius, so either do the 45 or straight.
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 02:43 PM |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 09:43 PM |
| Compiled 1NZFE Used Oil Analysis | craigq | DIY / Maintenance / Service | 7 | 09-10-2007 05:27 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 03:56 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 09:16 PM |
