Old 05-07-2014, 06:32 PM   #1
rc_osu
Drives: 2012 Yaris Sedan
My yaris seems to slide sometimes..
I've just recently got my Yaris (2012 sedan) and I'm really liking it a lot. However, I've noticed that when I drive over a grove in the road, the car wants to kind of slide along it (for lack of a better word). I've owned some small cars before but hadn't noticed this problem. Does anyone know what causes that and if there is anything I can do to correct it (i.e. change tires or shocks or something).
Thanks,
Ryan
rc_osu is offline   Reply With Quote
Old 05-07-2014, 06:36 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Very well could be the tires from the factory if you haven't upgraded them. Which ones are they? And welcome to the community!
Old 05-07-2014, 09:32 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
sounds like a tire thing. It happens on all sorts of cars sometimes.
Colin Chapman disciple
Old 05-08-2014, 12:07 AM   #4
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
I removed the fuse for the power steering to fix that. You're choice. Put the fuse back in once it was lowered and all is well!
trunkout is offline   Reply With Quote
Old 05-08-2014, 12:23 AM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Slow down ...lower tire pressure would not be surprised that they are to high as for power steering how would that make a difference ...
Sent from my XT1032 using Tapatalk
Old 05-09-2014, 09:33 PM   #6
nookandcrannycar
re lower tire pressure. I noticed a greater feeling of stability when I lowered pressure from 38 PSI to the Toyota recommended 32 PSI.
Old 05-08-2014, 11:12 AM   #7
rc_osu
Thanks for the responses! I think that they the original tires; I bought this from Enterprise car sales and it only had about 40,000 miles on it.
Not sure what my tire pressure is but I will check!
When it comes time to replace the tires, any suggestions?
Old 05-08-2014, 09:05 PM   #8
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Lots of good suggestions can be found in the Wheels, Tire and Suspension forum.
You may also want to consider lowering your center of gravity and/or a swaybar. I've done all of the above on my LB and it rides like a dream on highways.
Old 05-09-2014, 07:06 PM   #9
SKurj
Drives: 09 Yaris 3dr HB, BRZ
My car lowered with rr sway likes to get a little loose in the rear especially when spirited in the wet.
Its been a looong time since I drove one on the stock suspension but that's likely a major contributor to the feeling.
SKurj is offline   Reply With Quote
Old 05-09-2014, 09:31 PM   #10
nookandcrannycar
Thanks,
Ryan
This particular post prompts me to think that you might find any/some of Kimona's posts on tread patterns helpful. Just do an advanced search under his user name with 3 keywords: tread, pattern, patterns.
Old 05-09-2014, 11:33 PM   #11
kimona
kimona's Avatar
Drives: 2014 White VITZ
^^^ At 38PSI, my car bounced around like a basketball!
Old 05-10-2014, 02:04 AM   #12
nookandcrannycar
Old 05-10-2014, 05:03 AM   #13
Rigaud
Drives: 2009 Yaris
205/45R16 and I run 28psi front, 24psi rear on a 2009 3HB. on the 185/65 I ran 30 in front and 28 rear. Any higher is nuts for me.
Old 05-13-2014, 08:46 PM   #14
SKurj
I run 40psi all around.. just hunting for mpg though.. I do 900+ kms a week.
Just put the summer wheels on and didn't check the pressures, car felt bouncy and too smooth, I knew something was up.. Now the pressures are where I prefer them! back at 40 from 25ish
Old 05-16-2014, 12:25 AM   #15
trunkout
4 years of P90X!
I usually go to max.
same here!
Old 05-09-2014, 11:50 PM   #16
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
I'm running 40psi...
You are what you drive.
428CobraJet is offline   Reply With Quote
Old 05-10-2014, 12:55 AM   #17
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
40 is to much ...really don't understand why run so high ?
Old 05-10-2014, 01:03 AM   #18
428CobraJet
Now you tell me!
However. ..mine seems like a rock. Maybe I've the special tuned suspension? or it could be the aluminum Mazda2 wheels?
Or maybe 40 is the new 30?
Craig
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 04:13 AM
