Old 11-21-2013, 09:57 AM   #1
thomas667
Drives: 2011 yaris
Changed the drive belt on my 2010 Yaris
I have read the threads on changing the belt and seen that that lower alt bolt was a problem to get loose. So I searched the net and found this tool that is made for Toyota alt bolt it fits perfect around the alt pulley or if you go from under the car it works even better. Tool is Assenmacher Toyota serpentine belt wrench Part # ASMTOY1914. With this tool replacing this belt was breeze. Hope this helps everyone wanting to replace this belt.
thomas667 is offline   Reply With Quote
Old 11-22-2013, 11:55 AM   #2
alanwagen
tool
Thanks for the tip. It looks like a nice tool. Worth the price instead of paying someone. Here is a link on Amazon.
http://www.amazon.com/Assenmacher-AS.../dp/B008OSCWNS
Old 11-28-2013, 01:10 AM   #3
thomas667
Drives: 2011 yaris
Yes this tool is good.
Old 11-25-2013, 09:18 AM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
weird.. a normal wrench did the trick here.
Old 11-28-2013, 01:12 AM   #5
thomas667
Drives: 2011 yaris
Don't know what a normal wrench is bt if use a 3/8 ratchet it hits the crank pulley and ur on an angle which will strip the bolt bt hey to each his own .
Old 11-28-2013, 09:29 AM   #6
IllusionX
use a wrench instead of a 3/8 socket drive.
Old 11-28-2013, 11:43 AM   #7
Yeah, thanks to the A/C lines, it is a very tight space. Depends on your ratchet set. I have one 3/8" that will not fit, and another with a slightly thinner head which will just clear the lines. I use it to break the bolt free, then finish backing it out with a wrench.
Old 11-25-2013, 10:04 AM   #8
That would appear to be an excellent application specific tool.
Provides the benefits of a socket for maximum bolt head grip, the low clearance benefits of a wrench, and the torquing benefits of a breaker bar.
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
Could the 07-08 yaris s front lips actually fits 2010 yaris? Adward10 Cosmetic Modifications (Exterior/Interior) 3 03-18-2013 12:06 AM
