Old 07-30-2010, 07:26 PM   #1
ThuyDuong
Drives: yaris
yaris engine oil ?
hello all... i just got a new car now looking for engine oil ..very confusing dont know which one to get ..any suggestion please?
ThuyDuong is offline   Reply With Quote
Old 07-30-2010, 07:37 PM   #2
bst82551
bst82551's Avatar
Drives: 2008 Flint Mica Yaris Sedan
I use AMSOIL 5W-30 in mine, but I don't know what is available in Australia. Sorry.
-Brian
bst82551 is offline   Reply With Quote
Old 07-30-2010, 10:16 PM   #3
sleey0
Drives: 2008 Yaris LB
Royal Purple 5W30 in mine.
You can't go wrong with either amsoil or RP but I would stick with those 2.
sleey0 is offline   Reply With Quote
Old 07-30-2010, 11:36 PM   #4
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
Castrol GTX 5w30 in mine... with Fram Toughguard filter (7500mile/12000km)
I might switch to Castrol GTX High Mileage 5w30 once I crack 100000 miles.
salmonz is offline   Reply With Quote
Old 07-31-2010, 04:27 AM   #5
mimelio
Drives: NONE
Mobil 1 5W-30
mimelio is offline   Reply With Quote
Old 07-31-2010, 11:54 AM   #6
Hershey
SHELL 5w-30 conventional ( dino ) .
Old 07-31-2010, 12:34 PM   #7
Billiam
Drives: '10 White Yaris 4D LB
Ok....here's what's going to happen. You're going to get a different answer with each post. Everyone has their favorite oil and filter. There is no "best" oil. There will be an argument or 2 about which oil "better"...usually from the synthetic users...my oil can beat up your oil type stuff. Then after a few days the thread will probably be locked. No worries though, as a new one will pop up right behind it.
So...go to your favorite store and find some 5w-20 and a filter and be happy. Any and all modern oils (dino and synth) will protect your engine just fine for 5000 miles (however many KMs that is). The most important thing is to follow the recommened intervals and proper oil weight.
Oh...and for the record...I've used Castrol GTX and a PureOne filter on all of my cars for as long as I can remember.
Now excuse me...as I go pop some popcorn and sit back and watch another oil thread "evolve".
If you want to enjoy your car, stay off of the internet.
Old 07-31-2010, 12:47 PM   #8
RedRide
RedRide's Avatar
Exactly!
Any compitent mechanic will tell you that most all modern oils are basically the same and the important thing is to just change it frequently.
BTW, as I understand it "high milage" oil is just oil with some added detergents to help clear out sludge. However if you change it often you will not have sludge to begin with.
Old 07-31-2010, 05:39 PM   #9
mimelio
Drives: NONE
Originally Posted by RedRide View Post
Exactly!
Any competent mechanic will tell you that most all modern oils are basically the same and the important thing is to just change it frequently.
BTW, as I understand it "high mileage" oil is just oil with some added detergents to help clear out sludge. However if you change it often you will not have sludge to begin with.
+1
Old 07-31-2010, 08:57 PM   #10
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Originally Posted by mimelio View Post
+1
++1.....use what your manual says,can't go wrong!.
frog13 is offline   Reply With Quote
Old 12-08-2013, 11:51 PM   #11
frog13
Tw200--excellent!
I've noticed in various posts,that alot of folks "seem" to frown upon Toyota engine oil (Dino)....why is that?. Even the Dealership I bought my Yaris from uses Kendall?. Bulk oil rates perhaps?. TIA
Old 12-09-2013, 12:57 PM   #12
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
^ correct. Dealerships do not get am much of a kickback with the Toyota branded lubricants as they can with others.
I run Amsoil Dominator Racing oil, but if I weren't boosted I would run their EA 5-20 Signature Series. One of the main reasons why I choose Amsoil is that they are constantly looking for better ingredients for their lubricant formulas whereas most competitors have the same one for too many years to count just raking in the cash. Another obvious reason is the tremendous change interval. The 1nz can go 15k miles or 1 year between changes. This translates to an overall cost savings for many folks as well as time in maintenance.
As stated above however these oil specific threads are useless and overly abundant.
Old 12-09-2013, 02:11 PM   #13
Napa is my choice. I find that Napa synthetic (which is made by Valvoline) is cheaper than non-synthetic big brand oils.
Old 12-09-2013, 02:32 PM   #14
IllusionX
Drives: 07 Yaris Sedan Aero
CTScott is sold by Napa :)
Anyways.. Dealers in my area, including most of the garages that buy oil in bulk use mostly Castrol GTX. If you ask for Synthetic, you probably going to end up with Mobil1.
But i'd say either oil is fine. Just change your oil on schedule based on Toyota schedule. More often if you drive under extreme conditions.
I used to use RoyalPurple, because i want synthetic oil in my engine, and it cost almost the same price to get it in specialized shops compared to mobil1 in retail stores.
Old 12-11-2013, 11:03 AM   #15
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
5w30, whatever is on sale and name brand.....semi syn or syn is better, but, I save monies....I do use only Toyota F2 filters though....Been using the 5w30 mobil super 5000 as of late....walmart has it for 14.73 here in the SE USA
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
Old 12-11-2013, 02:17 PM   #16
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
From my experience, 5W-30 gives better fuel economy and power,
while 0W-40 makes the engine run noticeably more quiet.
I regularly use Mobil 1 5W-30, with 10,000 km (~6,200 miles) changing interval.
Mittelklasse is offline   Reply With Quote
Old 12-11-2013, 06:01 PM   #17
JustPassinThru
Drives: No more Yaris
Okay. For what it's worth...with my 2009, I used Mobil 1 5W-30 after the first 10,000 miles...I never had a problem I needed to have repaired, but I was getting some interesting engine sounds that resembled a lifter issue. Performance wasn't affected that I could tell, and the Toyota dealer told me to just run it. Digging in before a failure would cost money and maybe cause more problems than they'd find.
I continued with Mobil 1 until I sold it at 79,000 miles. I figured with a deer collision, high-siding a traffic island, four winters, and towing a motorcycle trailer, as well as being towed on a dolly for three thousand miles...it was time to quit while I was ahead.
The 2012 I bought under the Toyota program that includes free oil changes; so so far, with 14,000 miles on it, it's only had the dealer's mineral oil. No issues. When that program runs out, I'll switch to Mobil 1...be interesting to see if I get the engine clatter again.
JustPassinThru is offline   Reply With Quote
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Synthetic VS. Regular oil reliability captainm27 DIY / Maintenance / Service 98 01-20-2010 02:46 PM
Anyone running Royal Purple? firebird1999us DIY / Maintenance / Service 80 02-27-2009 11:30 PM
