Old 12-13-2013, 04:27 PM   #1
Aineal
Drives: Toyota Hatchback Yaris 2010
Installing AMP 2010 yaris HB
I was planning to get this bass package from crutchfield
http://www.crutchfield.com/p_236MB21....html?tp=61893
i just need suggestions on where to put the amp. should i just screw it on the subwoofer box?
thank you
Aineal is offline   Reply With Quote
Old 12-14-2013, 12:40 AM   #2
TOLMACH
Drives: soarer
Screwing it to the box would definitely be the easiest option
There is also plenty of space under the passenger seat.
Old 12-14-2013, 02:22 AM   #3
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
There's a lot of room under the passenger seat. I installed my 21" long 4 channel amp under there. If you install it on the box, you'll need to run some pretty large gauge wire all the way back from the battery. Under the set would be a much shorter run, and you could use smaller gauge wire.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
UberSilver is offline   Reply With Quote
Old 12-14-2013, 04:00 PM   #4
Aineal
ok thank you so much for the replies! its going to be my first time doing this so crossing fingers lol
is it hard to remove the passenger seat? after i remove it do i just screw the amp on the floor or do i need to do something else ?
Old 12-14-2013, 05:33 PM   #5
4 E10 torx head bolts. Slide seat forward to reveal 2 in the rear of sliders, slide seat back to reveal 2 in the front of sliders.
Old 12-14-2013, 05:58 PM   #6
TOLMACH
Drives: soarer
floor is uneven - you would need to buils some sort of podium..
you're gonna need some basic tools like jigsaw, drill, some mdf, etc.
Old 12-14-2013, 06:24 PM   #7
Aineal
I dont have that much tools on where i am now , i was just thinking on mounting the amp on a plywood and hiding it securely under where the spare tire is :/
Old 12-14-2013, 06:40 PM   #8
TOLMACH
Drives: soarer
that should be ok
buy some cheap amp wiring kit from e-bay,, should be around 15 dollars
Old 12-14-2013, 07:13 PM   #9
Aineal
Thank you so much ill post update once i have everything :)
Old 12-14-2013, 07:58 PM   #10
TOLMACH
Drives: soarer
go with 4 gauge kit
Old 12-15-2013, 12:26 AM   #11
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Keep the ground as short as possible. Remember to fuse the amp within 18" of the battery as well.
Also, before you turn on the amplifier turn the gain all the way down...just in case you have any Voltage spikes when turning it on. Take a look at the options for the amplifier's crossover section to make sure you've dialed everything as well as possible before you turn it on.
― Thomas Paine
Old 12-15-2013, 01:13 AM   #12
nookandcrannycar
How did you solve the floor issue that TOLMACH mentions in post #6 ?
Old 12-15-2013, 08:19 PM   #13
TOLMACH
Drives: soarer
^ This is how TOLMACH did.. small pod, covered by the automotive carpet. blue wire is ground, positive is well protected.. crappy interconnects are for subwoofer amp - look like garbage but do the job
i then changed the seats, hence had to move the second amp to the other side
front amp interconnects are on the other side (self-made)
Old 12-15-2013, 08:21 PM   #14
TOLMACH
Drives: soarer
(i know.. could not find any hear shrink tube around (( now buy this stuff from e-bay)
Old 12-15-2013, 08:22 PM   #15
TOLMACH
Drives: soarer
^ some good pieces of advice
Old 12-15-2013, 09:40 PM   #16
nookandcrannycar
^ Thanks .
Old 12-15-2013, 10:21 PM   #17
Aineal
thanks for the tip!
can someone give a link for a good amp kit on ebay or anywhere
for this bass package : http://www.crutchfield.com/S-FNtFp7r....html?tp=61893
Old 12-16-2013, 12:11 AM   #18
TOLMACH
Drives: soarer
http://www.ebay.com/itm/23-OVERSIZE-...item4d0df2b7cc
I like that they say their gauge 4 is real gauge 4 (25 mm2)
Cheaper stuff will also do the job
http://www.ebay.com/itm/4-Gauge-Amp-...item19e59d8f2c
2010 Yaris Stereo Install Help FPG In Car Entertainment + Electronics (audio / video / alarm) 13 04-21-2012 10:16 PM
CONSUMER REPORTS : March issue : 2010 YARIS sedan Hershey General Yaris / Vitz Discussion 41 02-18-2011 04:41 AM
