Old 01-21-2014, 01:02 AM   #1
ZAKU
Drives: 2007 Yaris RS
Bleeding brakes with non-functioning ABS?
Need to flush the brake fluid on my 2007 Yaris, but my ABS is currently not working (wiring corroded/broken, fuses pulled).
My major concern is that reading online leads me to believe the ABS unit must be "cycled" to fully flush the fluid. Is it possible to jump a relay or something to cycle it? Or am I stuck trying to find someone with a fancy OBD scan tool?
The FSM seems pretty vague in regards to bleeding the brakes so some guidance would be appreciated.
ZAKU is offline   Reply With Quote
Old 01-21-2014, 07:17 AM   #2
The Yaris has a very primitive ABS system where you don't have to cycle the ABS when bleeding an ABS equipped one. So, just bleed them as you normally would.
Can I Disable ABS Brakes? Posker Performance Modifications 25 03-05-2022 05:03 PM
ABS brakes Highway Star Cosmetic Modifications (Exterior/Interior) 4 01-19-2012 12:24 PM
ABS brakes / Would you buy a Yaris without them? 3cyltrbo General Yaris / Vitz Discussion 66 03-26-2011 09:21 PM
ABS?, Grinding Noise When Brakes Are Locked!??? p0pNfr3sh DIY / Maintenance / Service 3 03-03-2010 06:22 AM
ABS Brakes Kid General Yaris / Vitz Discussion 13 04-23-2007 05:05 PM
