#1 |
![]() Drives: 2008 Toyota Yaris Join Date: Feb 2012
Can I Disable ABS Brakes?
Does anyone know if I can disable the ABS brakes on my 2008 Yaris? I've been told you can do this by removing a fuse. If so, are there any side effects. i.e. will this effect anything else and is it legal in Ontario?
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
why would you want to remove it?
Yes it will have side effects like lock up under hard breaking. |
#3 |
You could pull the ABS1 (30A) and ABS2 (50A) fuses in the under hood fuse panel, but the ABS ECU will still be alive, but will not be happy.
The other thing that you can try is to open the wire that goes between connector 4B pin 21 and the ABS ECU. This is the feed from the brake switch, that tells the ABS ECU that you are pressing the brake pedal. In theory, disconnecting it will keep the ABS ECU from activating the ABS since it won't know that you are pressing the pedal. If that works, then you could insert a switch and be able to enable/disable ABS on demand.
#4 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
Maybe the OP is interested in drifting/power slides? I'm having a hard time thinking of a good rationalization for it. As far as legality, I can only find documentation that requires commercial vehicles (semi trucks, buses, etc) to both have ABS and have them inspected regularly.
#5 | |
If you know how to drive, especially if you've had some training with brake modulation (ahem = racing experience) -- non ABS is way better. EVERY DRIVER should have to do this to get their license, IMO: http://www.raceschool.com/about-fast...iew=categories In general, race cars don't use ABS. More control without it.
#6 | |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
Race cars don't have it because the rules prohibit it. If the rules allowed it all race cars would have ABS. To which I would say: If production ABS systems' sensitivity were infinitely user-adjustable like a race car's would most likely be, I would welcome it too. As it is, production ABS systems are too sensitive (especially Toyota's) and kick in way too soon. Threshold braking requires some slipping of the tires to be at max braking but the Yaris' ABS interprets this as lock up and releases the brake pressure prematurely. Frankly, I think nanny-technology has created worse drivers. Thinking that ABS, traction control, airbags, seatbelts, etc., will save their asses, most people (as evidenced by how many people yak on their cell phones and/or text and drive) just don't care how poorly they drive. |
#7 | |
#8 | |
Only Happy When it Rains
Not to mention in most emergency situations the last thing you want to do is slam on the brakes, even with ABS it gives you less control over the vehicle. Slamming on the brakes should always be a "last ditch I have nowhere to go and if I don't stop right now I will die" choice. Not a "it is snowing hard and I can't feel what the car is doing and some jerk just cut me off and even though there are 3 empty lanes all around me I am still going to slam on the brakes for the hell of it choice." The safest way is to not have to use your brakes and to never be put into a situation where it is stop or die. That means assume everyone around you wants you dead and keep the heck away from them.
Colin Chapman disciple |
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
I get a kick when shows talk about all the cars on the roads in Cali and they show a busy highway. At least they're moving. Unlike around Toronto.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#10 |
Actually, many race classes do allow it. Mostly I think it's because they are stock or near-stock classes. Just my opinion on that one, though.
But you are wrong about seatbelts.
#11 |
^ Yep, ok I will agree that in extreme weather ABS might be useful to you.
But then I had to look up what the word "snow storm" meant...
#12 |
hahaha
![]() I totally agree with on track in certain cases because I've been in that situation where the ABS almost put me off track. But that aren't all created equally. My friends went from an old 90 CRX to a new 08 civic (both fully prepped race cars) and said how much deeper they could go with the heavier ABS equipped civic into the corners. But honda's system isn't nearly as intrusive as toyota's. |
#13 |
![]() Drives: 2010 Yaris S HB Join Date: Nov 2011
^ Lol. Around here, that's the only way to drive regardless of weather conditions. on the rare occasion that we get snow/ice, you might as well stay home if you don't have 4WD/AWD; the roads won't get cleared until the sun does it, and most people who do get out either think they're invincible because they do have 4WD, or want to go 10 MPH because they don't.
#14 |
i don't have abs on my yaris and when its super snowy, i drive carefully knowing i don't have abs to help me if i lose control
the aveo doesnt have abs either you know what? because i don't have abs, i drive safer in shitty conditions...
#15 | |
#16 |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
I'm all for ABS. Especially on the street, where both you and your environment aren't prepped like at a track day.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
#17 |
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
...I had no idea we had ABS. i assumed we didn't, so I never thought to check. Disablin'
#18 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I disable my abs/tcs for the winter...in the summer it doesnt kick in much with the tires inflated so high...go figure
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
| ABS brakes | Highway Star | Cosmetic Modifications (Exterior/Interior) | 4 | 01-19-2012 12:24 PM |
| ABS brakes / Would you buy a Yaris without them? | 3cyltrbo | General Yaris / Vitz Discussion | 66 | 03-26-2011 09:21 PM |
| ABS?, Grinding Noise When Brakes Are Locked!??? | p0pNfr3sh | DIY / Maintenance / Service | 3 | 03-03-2010 06:22 AM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 07:04 PM |
| ABS Brakes | Kid | General Yaris / Vitz Discussion | 13 | 04-23-2007 05:05 PM |
