![]() ![]() Drives: 2009 Toyota Yaris Sedan S Join Date: Aug 2009
Stock OEM front struts, aftermarket rear shocks?
Does anyone run this type of setup? Or do you have to replace the struts and shocks altogether? Thanks!
#2 | |
With the Yaris having so much of its weight up front (and being front wheel drive), the fronts are really more important for performance than the rears are.
Thanks, CTScott. I was wondering about that. I'm trying to dampen the rear cause it'll occasionally bottom out on dips on the freeway especially with people (I have a large sub box in the trunk)
I am not sure that rear shocks will completely cure that. The bottoming out is due to the springs fully compressing. Stiffer shocks will slow that process down a bit, but will still allow you to get to that point. I would think that stiffer springs (or something adjustable) back there would be the solution.
#6 | |
I may not be completely correct with my assessment, so hopefully some of the lowered people will weigh in on this.
stiffer rear will get you more over steer. It could be very dangerous if you are inexperienced driver..
If you do get stiffer springs, be sure to use the same spring front/rear ration than OEM, unless you know what you are doing. |
#9 | |
^ Now he tells us. LOL. So yes, you are lowered and bottoming out, with passengers and an audio system. Sounds about right. Stiffer rear shocks will help, but Tokico HPS blues may not be enough. HTS reds are adjustable, I'd have to check to see if I can get a pair only.
You can also get shock bump stops or spring spacers to prevent the bottoming out, BUT there is a sacrifice in ride quality when they hit the stops.
#11 | |
I just won't drive anyone in the back anymore... do you have a 2 seater conversion, cali yaris? hahaha, jk |
#12 | |
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
^^ agreed with Myztic. It's much cheaper to find out if it works, anyway.
#15 | |
Just put your stock springs back into the rear. Simple and free.
^ But he has Sportlines, that would make the car look horrible.
| 09 Stock HU - front and rear AUX in? | azeeroth | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 08-10-2012 11:37 AM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Aoe TigerTec..4k front, 3k rear....Tein Stech 3k front, 3.5k rear? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 10-15-2009 11:44 AM |
