Old 10-13-2009, 10:57 PM   #1
detroiter
detroiter's Avatar
Aoe TigerTec..4k front, 3k rear....Tein Stech 3k front, 3.5k rear?
So one company is stiffer up front while one company is less up front but stiffer in the rear, what really is the better choice of the two? And why would they make the spring rates vary like that from front to rear?
Old 10-14-2009, 01:10 PM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
personally, i like the teins better. the car seems to like more rear bias. now i used DF210's with a 23mm rear sway bar juuust fine for a long time. they are 3kgF/2.2kgR, so the tigertecs are about the same. so you could probably do either, and it wouldnt even matter, especially if you play around with tire pressure.
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 10-14-2009, 01:30 PM   #3
^ agreed, and there is the price point to consider. As far as I know, the AOE TigerTecs are the best deal on springs you can get.
Old 10-14-2009, 11:45 PM   #4
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Do the rear TigerTecs cause sagging over time?
Old 10-15-2009, 09:59 AM   #5
ddongbap
I wouldn't advise on getting super stiff rates on stock shocks. They wouldn't be able to keep up.
The different spring rate might just be because the car has different weight distribution from front to back.
Old 10-15-2009, 10:44 AM   #6
No one has reported this yet; they are still a new product. There are 17 sets out there, all customers have liked the springs and no complaints at all.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
