Old 03-10-2014, 11:41 PM   #1
dragoonmc
Drives: 07 hatchback
radio hooked up to stay on while starting?
Hey guys,
My radio has a boot sequence that is pretty slow and I use my phone to play music so after the boot sequence it then has to connect to that to play music.
I was wondering if there was a different ignition switched power wire I could connect to so that it stays on while I start the car.
dragoonmc is offline   Reply With Quote
Old 03-11-2014, 12:07 AM   #2
The easiest way to do it is to bypass the ACC Cut Relay (which is mounted to the left side of the under dash fuse panel).
You can do by jumping one of the white wires in pin 3 to the blue wire in pin 4. That will prevent the ECM from dropping power to ACC fed devices while the starter is cranking.
Old 03-11-2014, 10:12 PM   #3
dragoonmc
awesome thank you very much
Old 03-12-2014, 11:51 AM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Is that circuit not there to prevent accessories from massive voltage fluctuation from the draw of the starter?
Old 03-12-2014, 12:10 PM   #5
It is there to help the car out with not having a draw from unnecessary devices while cranking. If the battery is good the voltage should not sag below 11V while cranking.
Old 03-12-2014, 12:10 PM   #6
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I was wondering the same thing.
-Type 07 FFL-
My odometer 03/11
Old 03-12-2014, 12:18 PM   #7
Bluevitz-rs
At -15°C or even colder, I can guaranty voltage will drop below 11V. I know my battery is not in it's prime anymore as it came used from an '03 Vitz RS that was in the shop when I work at Toyota Canada. It drops to 8.5V when cranking in cold temps and causes my auto locks to play up. On occasion some doors won't lock or unlock. And I always turn off everything when starting my car, including the fan. I'm just hoping to get the summer out of it.
Old 03-12-2014, 12:29 PM   #8
8.5V is mighty low. At just a tad below that the ECM will start acting flakey.
Old 03-12-2014, 12:31 PM   #9
Bluevitz-rs
Yeah I know! I've since charged my battery and it's gotten warmer, but haven't tested it again.
Old 03-12-2014, 11:22 PM   #10
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've been having consistent stall issues when coming to a stop, so this will be a nice fix for the head unit developing amnesia and having to re-read the CD every few miles.
Old 03-12-2014, 11:57 PM   #11
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
As always anything given on a forum like this is give with an implied disclaimer that if you do something without proper thought or research is done at your own risk.
Personally if I had a battery that is dropping that low during cold conditions especially it would get junked. Why is it worth the risk to possibly get stranded somewhere or heaven forbid be in an emergency situation and being SOL due to a preventable scenario?
Old 03-13-2014, 12:09 AM   #12
Bluevitz-rs
I'm never anywhere I would be "stranded" so it doesn't make much difference to me. I have the original battery hooked to my off grid solar system right now, and it's not as cold anymore. I'm also not starting and shutting it off as repeatedly so it isn't killing the battery anymore.
Old 03-13-2014, 12:19 AM   #13
fnkngrv
fnkngrv's Avatar
makes sense and good to hear
Old 03-13-2014, 12:05 PM   #14
mazilla
advocatus diaboli
mazilla's Avatar
1zz TB?
-Type 07 FFL-
My odometer 03/11
Old 03-13-2014, 06:55 PM   #15
nookandcrannycar
Having just switched from a struggling battery that tested bad, to the NAPA Legend (model that CTScott has), I have to say that I agree with this in spades. I think that NAPA Legend may just be the best battery I've put in any car I've ever owned.
Old 03-13-2014, 07:09 PM   #16
nookandcrannycar
Although your suggestion doesn't apply to Bluevitz-rs (given his personal experience), Having driven to Madawaska last year (took the 'river route' after the road splits...so I didn't go through Caribou), I can see why getting stranded would be something a prudent person in your area would think about....a beautiful, bucolic area....but getting aroung in the winter..... I guess it is something you get used to and get better at...and for natives of Maine, I imagine getting around during the winter is second nature.
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 03:12 PM
Custron T1062TYT Review (Long) mr.steevo In Car Entertainment + Electronics (audio / video / alarm) 1 11-24-2011 03:13 PM
ATL, I want to trade my Upgraded built in radio... matthewallanstill Southeast 2 03-28-2009 07:29 PM
Mounting a CB radio somewhere Sodium Duck Cosmetic Modifications (Exterior/Interior) 1 03-06-2009 02:50 AM
I want to trade my Upgraded built in radio... matthewallanstill Items for Sale by private party 0 09-03-2007 10:50 AM
