SRS light repair
My SRS light is on, and I've got two DTCs: 43 and 51.
Tracking down 43 first, I've gotten to page RS-128 so far, where Step 5 measures the resistance between D16-17 and D16-23 at the center airbag sensor assembly. The manual says there should be 1MΩ or higher, but mine measures 800KΩ. What does this mean? It's not a full short, but partial short?? I'm really hoping I don't have to replace the instrument panel wire, and I have no idea how that wire could have been broken. |
Ok my bad. It turns out the reason for DTC 43 is that the passenger airbag light was disconnected (due to some radio wiring I was doing earlier).
Anyway, moving on to DTC 51. I've made it to RS-146, Step 5f, checking for a short. After releasing the activation prevention mechanism in Connector B, I measure resistance between D18-1 and D18-2 at 200KΩ. It's supposed to be 1MΩ or higher. So the solution is to replace the instrument panel wire. But if it's a short, wouldn't the resistance be zero? Why am I getting 200KΩ ? I wonder if there's something weird with my electrical system, because this is similar to the test in my last post. |
Ok I answered my own question. The resistance was low because I was holding the multimeter leads with my fingers. Duh!
Did you find anything yet with the 51? The most common cause is a bad spiral cable (clockspring).
Yep, it is indeed a bad spiral cable. I took the spiral assembly apart, and I see one little spot where the insulation is worn down and one wire is broken. This exact same thing happened to this car 3 years ago. Weird. I already know I'm not skilled enough to solder the joint, so I'll be looking around for junkyards.
Can you think of any reason the exact same problem would occur twice in 3 years? |
#6 | |
Hmm, not really. I'm in Orange County, but I rarely go to the beach.
For the insulation to wear through, you are either getting some type of contamination within there that abrades it, or the lubricant that they coat the cable with is breaking down.
Yeah... Maybe I should vacuum the car more often. I do have a carpeted dash cover. I wonder if that is somehow trapping dirt from the air, and then... I don't know... dumping it onto the steering wheel or something. Has anyone else ever had a clock spring go bad by itself? I've just never heard of it happening, except when people aren't careful removing the wheel.
Over the years on here I have seen about half a dozen people have clocksprings fail on their own.
#11 | |
This is interesting. Toyota issued a recall for spiral cables in some Tacomas, saying:
They are different part numbers, but it does sound like the same issue.
SRS light repair
I just bought a $50 new aftermarket spiral cable, and if works fine, but I can hear a scraping sound when I turn the wheel. I think it's the 2 short wires that connect to the airbag, maybe they're slightly too long and rubbing on the airbag?
They should be pretty stationary since they connect between two points within the wheel. Hopefully the scraping is not an indication of the quality of an aftermarket clockspring.
Hooray! Toyota has just announced a safety recall for this, affecting the Yaris and many other models.
http://www.autonews.com/article/2014...llion-vehicles I'm going to take advantage of this instead of the aftermarket part. I'm going to see if they'll give me the part with extra wires for audio controls if I pay the difference. Then it might be possible to DIY some steering wheel buttons to connect to an aftermarket stereo. |
#16 | |
#17 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
I guess the quesion is, are the clocksprings different for cars that don't have SW buttons from the factory as compared to ones that do? |
#18 | |
On pre-2012 Yaris for the US market there was not even an option of having steering wheel controls. Importing a European or Japanese clockspring was the only way of doing a vehicle specific upgrade.
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 02:50 AM |
| SRS warning light - any guesses? | Goose | DIY / Maintenance / Service | 15 | 03-24-2014 02:57 AM |
| Toyota Yaris Battery Light On - Repair | gabo | General Yaris / Vitz Discussion | 1 | 08-24-2011 08:21 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 04:41 AM |
