Yep, it is indeed a bad spiral cable. I took the spiral assembly apart, and I see one little spot where the insulation is worn down and one wire is broken. This exact same thing happened to this car 3 years ago. Weird. I already know I'm not skilled enough to solder the joint, so I'll be looking around for junkyards.
Can you think of any reason the exact same problem would occur twice in 3 years? |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| SRS warning light - any guesses? | Goose | DIY / Maintenance / Service | 15 | 03-24-2014 01:57 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
