![]() Drives: 02 vitz rs Join Date: Feb 2014
1nz throw out bearing D.I.Y?
anyone ever change the throw out bearing for the 1nzfe?
looking for a repair manual, but not seeing one.
so many pedestrians..... so little time
2ZR swap. DO IT! Ask how!
Check out microimageonline.com. They have the whole OEM manual available in pdf. The bearing itself takes only a few seconds to replace. Getting the transmission off takes several hours.
ok... def not seeing it, can someone please post it here from microimage.
THANKS
| Alternator Bearing | barryware | DIY / Maintenance / Service | 7 | 11-23-2013 06:33 PM |
| Bad trans bearing | Topaz540i | DIY / Maintenance / Service | 9 | 04-15-2013 02:51 PM |
| Yaris 2007 ABS & Brake light issue after wheel bearing change | DevilzMafia | DIY / Maintenance / Service | 4 | 01-17-2013 09:24 PM |
| Throwout Bearing Failure | blazing hatch | DIY / Maintenance / Service | 7 | 06-03-2012 08:44 PM |
| Urgent advise Needed MT Clutch & Bearing Spec. | victorddr | DIY / Maintenance / Service | 4 | 04-23-2011 10:27 AM |
