Old 06-01-2012, 05:53 PM   #1
blazing hatch
Drives: 2011 3dr HB, 2007 sedan
Throwout Bearing Failure
I just took my 11 yaris hatch in to have the throwout bearing replaced, thankfully under warranty. It's current mileage is only 21,000. So it has me alittle concerned about this being a continual thing. By the way this is not my first vehicle with a manual trans. Been driving a stick for years, and this is my first brand new car. I've replaced clutches before but never just for the throwout bearing.
I was wondering how many of you guy with manual trans Yaris, have had to replace the T.O. bearing? and at what mileage interval? My wife's 07 sedan with auto trans has 50,000 miles, and has needed nothing other then it's normal 5,000 mile servicing and tires. Thinking I should have bought and automatic trans now.
blazing hatch is offline   Reply With Quote
Old 06-01-2012, 06:41 PM   #2
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
usually a throw out baring wares out quickly if you leave your foot rested on the clutch peddle, this causes the fork to come into contact with throw out bearing and the pressure and friction will prematurely wear them out. I would assume that your previous automobiles had clutches that in gauged at a later point than the Toyota clutch peddle. just ensure that you don't rest your foot on the puddle while driving and you should be fine. (the things I learn in auto class :D) Ironically that was a point of discussion today so conveniently I happened to have recently obtained this information to pass on to you. :D
Old 06-01-2012, 06:58 PM   #3
blazing hatch
Ya, that's the thing. I never rest my foot on the clutch. So this should not have happened.
Old 06-02-2012, 12:37 AM   #4
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
hopefully it is just a freak thing. Never needed anything but normal maintenance on my car.
Colin Chapman disciple
Old 06-02-2012, 08:45 AM   #5
I hoon on mine all the time and have had ZERO clutch/tranny issues
Old 06-02-2012, 09:16 PM   #6
rick996
rick996's Avatar
Drives: 2010 5 door hatch w/5 sp man.
I think it's just a fluke "lemon" bearing. It happens even in the best of brands.
rick996 is offline   Reply With Quote
Old 06-03-2012, 01:52 PM   #7
blazing hatch
That's good. That's what I was hoping to hear. Probably just a bad one in the bunch.
Old 06-03-2012, 08:44 PM   #8
Golddeenoh
Golddeenoh's Avatar
yea sounds like it, lucky it is still under warranty so you shouldn't have any problems after that unless you get a double lemon part.
Alternator Bearing barryware DIY / Maintenance / Service 7 11-23-2013 06:33 PM
Bad trans bearing Topaz540i DIY / Maintenance / Service 9 04-15-2013 02:51 PM
Rod knock or Main bearing knock? jabranko General Yaris / Vitz Discussion 27 08-05-2011 11:14 AM
Urgent advise Needed MT Clutch & Bearing Spec. victorddr DIY / Maintenance / Service 4 04-23-2011 10:27 AM
Front Wheel Bearing Failure craigq DIY / Maintenance / Service 4 08-17-2007 07:26 AM
