Old 08-16-2007, 10:44 PM   #1
craigq
Drives: '07 Yaris, '12 GLI
Front Wheel Bearing Failure
Just an FYI: we just had the right front wheel bearing replaced under warranty. It began making a hollow, low-frequency noise/hum at approximately 8000km/5000miles.
The dealership was at first apprehensive about the problem (the "service adivsor" stated that it was normal and that all of the Yarii made a low-frequency hum, without even hearing it himself. I was adamant that the noise was not "normal") but once a mechanic performed a test drive they were quick to diagnose and replace the bearing.
craigq is offline   Reply With Quote
Old 08-16-2007, 11:13 PM   #2
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
woww..good thing i still have my stock factory rims/tires.
with my current set..they might not take it.
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-16-2007, 11:14 PM   #3
seanele
seanele's Avatar
btw..thanks for the info.
Old 08-17-2007, 06:23 AM   #4
Pavel Olavich
Drives: 2007 Yaris LB
Did you change out the factory wheels/tires before this started to happen?
Pavel Olavich is offline   Reply With Quote
Old 08-17-2007, 07:26 AM   #5
craigq
It happened with factory 15" wheels/tires.
rattles (front of steering wheel) wushumasterku DIY / Maintenance / Service 37 09-10-2007 11:24 PM
Scion xD Rudeshady Central and South America 1 06-25-2007 01:11 PM
