![]() Drives: 2008 Toyota Yaris 2D Join Date: Apr 2014
Rear wiper doesn't make full contact with window. How to fix?
2008 Yaris, the rear wiper doesn't press hard enough against the rear window to make full contact along the blade. How do i fix this?
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
IMHO it would be case of spring tension or a stiffened wiper rubber (for replacement).
![]() ![]() Drives: 2008 Hatch Red Join Date: Apr 2012
When I got my 08 hatch the rear wiper was very worn so I replaced it with an aftermarket blade, Trico 12-A. It made poor contact at the outer edges of the blade and I did some research online and came up with nothing.
I eventually got a good look at things and found that at one point the assembly actually bumps into another part of the assembly keeping it from pivoting enough to make good contact with the glass. I ended up filing or dremeling a small notch in one part of the plastic to allow clearance and all is good. I guess the aftermarket blade is not an exact copy of the Toyota part and wished I had kept the old blade and just used a refill. Getting a Toyota part or modifying the aftermarket one should fix the problem. The red line in the photo is the "filed down" notch. Probably does not need to be quite so wide. Last edited by andulong; 06-10-2014 at 08:09 PM. Reason: add photo |
| Full auto electric window | shtou | Yaris TS Talk | 6 | 05-29-2014 05:19 PM |
| Rear Wiper Motor | 49erRider | DIY / Maintenance / Service | 5 | 06-07-2011 12:12 PM |
| Rear window sedan crackling noise. | krolos | General Yaris / Vitz Discussion | 3 | 04-09-2011 01:39 AM |
| 07 rear wiper blade problem? | Suey 1958 | General Yaris / Vitz Discussion | 3 | 01-13-2011 06:54 PM |
| How-To: Liftback Rear Wiper Arm - Full Pivot! | Chris07LB | DIY / Maintenance / Service | 5 | 07-24-2009 04:08 PM |
