Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 10-27-2010, 03:52 AM   #1
shtou
Drives: YARIS TS 1.8
Full auto electric window
Hey friends, i'm asking you if somebody knows if it possible to make the passenger windows works full auto like the driver's windows.You know that our car has only in front electrical windows and only the driver's windows is full auto and illuminated button.does anybody knows a solution for this?i wonder if i would try with another windows's driver button to replace the passenger button it would work full auto?
another thing.does anybody of you installed an alarm module(or an entire alarm system) which "knows" to close the windows(electrical of course) when close the car?My TS is with keyless system and maybe with this system it is possible not working such a module?
Thanks.
waiting for your suggestion.
shtou is offline   Reply With Quote
Old 10-27-2010, 08:22 PM   #2
Here's a PDF that I put together for Mgargano, who installed the DEI 530T Auto window module, which allows two windows to do both auto up and auto down. If you have a 4 or 5 door, you can use two modules:
The Yaris is a "Type A" system, so set switch 5 to the OFF poistion.
For the Resistance setting, use the following: SW1-OFF, SW2-ON, SW3-ON, SW4-ON, SW5-OFF
http://www.yarisworld.com/forums/att...2&d=1253493376
Old 10-29-2010, 12:43 PM   #3
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
hey Scott I want my windows to come down and up when i click the Aux button on he remote starter clicker. any ideas?
Originally Posted by sw07gt
Old 10-29-2010, 09:53 PM   #4
That same module will do exactly that. It either can either auto open/close by quick press of the window switch or by input from a remote starter.
Old 10-30-2010, 10:15 AM   #5
JumpmanYaris
USAF_SrA_E-4
how do i link it to my remote?
Old 05-29-2014, 03:59 PM   #6
Kaeon
Drives: 2007 Yaris Hatch
I tried these resistance settings however my passenger window goes down a bit then stops. I have to re-engage the button at least five times to get the window all the way down. Anyone have any ideas?
Kaeon -
2007 Toyota Yaris Hatch
Kaeon is offline   Reply With Quote
Old 05-29-2014, 04:19 PM   #7
Try the different settings in the DEI manual until you find the ones that work for your car. Resistance will vary based on age and lubricant state for the power window motors.
