![]() ![]() Drives: Yaris 1F8 Join Date: May 2013
Spark plugs.
Hello guys they told me at the dealer to not touch the plugs before 192 000 kms.. is that possible ? What do you think ?
160k km I think from the maintenance schedule. But I changed mines at 120k
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Oct 2012
The maintenance schedule says 12 years or 192k km.
Roy |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
15 lbs/ft. Less if you use anti-seize.
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
remove
I would remove (50k miles), inspect , check the gap and put back in with anti-seize on the threads for easy removal next time. That's 50,000 us miles. torque? is usually skill of the craft but if you want to be specific it's usually around 20-25 footpounds, and no the value does not change with anti-seize on the threads. 20 foot pounds of pressure is still 20 foot pounds of pressure no matter if the threads have a lubricant on them, it'll slide in a little farther with the lubricant on but not to make a difference, 20 pounds is still 20 pounds. if you had a soft alloy metal that would bend or something I would say yes torque them less if the threads had lubricant, I don't think in this case.
#7 | ||
#8 | |
dude
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Most aluminum heads are just that, aluminum for the threaded part as well.
| Location of Spark Plugs | KEVBD | DIY / Maintenance / Service | 7 | 02-03-2012 11:05 AM |
| Laser plugs? - Awesome | Altitude | Off-topic / Other Cars / Everything else Discussions | 1 | 04-24-2011 08:02 PM |
| article on spark plugs and the fit | kngrsll | Performance Modifications | 4 | 08-01-2009 11:50 PM |
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 02:07 PM |
| Upgraded Spark Plugs For Boost | whooppee777 | Forced Induction Forum | 9 | 02-14-2009 01:53 PM |
