![]() Drives: yaris Join Date: Jul 2014
Horn Not Working
hi
i have 2012 Yaris hybrid (Hatchback) So...the horn doesn't work! Is there a relay or fuse that i should check - Diagrams Etc? or where locate the horn relay fuse is ok horn is ok - Zee |
The horn fuse and relay are located in the fuse box that is next to the battery. The relay is within the block that the fuse is mounted to, so replacing it requires replacing the entire "integration relay" block. Check the fuse first and if that is OK, have someone press the horn while you put your ear against the integration relay to see if you hear the relay contacts click when the switch is pressed.
this image(relay and fuse box)
where locate the horn relay ??? Thank you, CTScott! |
It is within that white block with the fuses in it. Look at the cover for the fuse box to see which fuse is the horn one and the relay is directly beneath the fuse within that block.
How to Remove white block ???
There is a tab on either end that you release
| Tags |
| horn not working |
| Horn Not Working | Zee518 | DIY / Maintenance / Service | 8 | 07-17-2016 09:05 PM |
| Help! Turn Signals and Horn Stopped working | kashanf | DIY / Maintenance / Service | 3 | 05-28-2014 06:20 PM |
| Car horn not working on the right-hand side | Toyota3000 | DIY / Maintenance / Service | 1 | 12-26-2013 02:57 PM |
| horn stopped working | sickpuppy1 | DIY / Maintenance / Service | 11 | 07-17-2013 01:32 AM |
| Help! Horn just stopped working. | steveh74 | General Yaris / Vitz Discussion | 14 | 09-17-2009 11:23 AM |
