Old 08-07-2012, 07:33 PM   #1
Zee518
Drives: 2008 Liftback White
Horn Not Working
First,
Just got my 2008 Yaris Hatchback and super excited to be on this forum!
Second,
So...the horn doesn't work! Is there a relay or fuse that i should check - Diagrams Etc?
- Zee
Zee518 is offline   Reply With Quote
Old 08-07-2012, 07:55 PM   #2
Zee518
- Just did some research,
Found that the 10 Amp fuse under the fusebox looks fine, when i press the horn down you can hear the relay click on and off - I'm guessing my horn is bad and needs to be replaced
Old 08-07-2012, 08:18 PM   #3
It could also just be unplugged (if someone did some front end work on the car at some point). If you shine a flashlight through the grill you should be able to see the single wire connected to it (the other connection is the bolt that mounts it).
Old 08-07-2012, 08:39 PM   #4
Zee518
I think you nailed it - I see a green wire clip thats just hanging from the grill...this might be connected to the horn.
Old 08-07-2012, 08:56 PM   #5
That's the horn wire. If you look for the thread on changing the headlight bulbs, it shows the easy method of freeing the top of the bumper, which will give you enough space to get your hand in and reconnect the wire.
Old 08-07-2012, 09:09 PM   #6
nookandcrannycar
CT....Wow. I USUALLY notice things in excruciating detail, but in the thousands of times I've looked at that picture, this is the first time it registered that Crashy is a different color blue than your 5-door. I should have noticed it before as I believe Crashy is my same Bayou Blue (the only other blue for 3-Door LBs until eliminated and the Mica came along in 2012....at least for the U.S. I think). At your convenience could you look at the questions on my little 5 line post #45 on tk1971's 'just picked this up - Prius C' thread in the Off Topic/Other Cars/Everything else discussions and post your thoughts. My last question in that post is "Are these CTScott only questions?" Thanks
Old 08-07-2012, 09:27 PM   #7
Zee518
I found this thread:
http://www.yarisworld.com/forums/sho...7&postcount=12
Thanks for your quick reply and help!
- Zee
Old 07-17-2016, 07:46 PM   #8
ACKING_QC
Drives: 2018 VW TSi Stage1
so SH!T HAPPENNED I was working on replacing horn on my LE... for hornS from my 1992 Celica GT-S wires are the same so it should work... made a mount to bolt the 2 celica horns on the OEM Yaris LE horn mount bolted them... CUT wires and extended them because otherwise, they would not fit... so we cut the OEM yaris wire (the wire that goes to the steering wheel and made some connections with some wire joints...) the wires are CORRECTLY done.... pressed horn.. didnt work... sand paper the mount guessing a bad ground.. still didnt worked.... we decided to put the OEM horn in place STILL doesnt work...the fuses all seems okay after a rapid check... so wtf is happenning ?
ACKING_QC is offline   Reply With Quote
Old 07-17-2016, 08:05 PM   #9
Measure the voltage between the horn wire and ground. If you don't have 12 V there with the horn switch pressed, then the wire between the horn relay and the horn may be damaged.
My horn install... Goose DIY / Maintenance / Service 7 01-29-2016 04:10 PM
where is my horn located? 2007 3 door Suey 1958 General Yaris / Vitz Discussion 6 11-27-2011 09:57 AM
My horn quit - not the fuse. m3ga_band_g33k DIY / Maintenance / Service 2 12-07-2009 07:11 PM
Help! Horn just stopped working. steveh74 General Yaris / Vitz Discussion 14 09-17-2009 10:23 AM
Toyota Premium Horn Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 22 02-18-2009 11:28 PM
